Difference Between Sc & Carrera Wires
Anyone know the difference between SC and 3.2 Carrera ignition wires? I have a Clewett set for a Carrera and wondered if there is any reason, other than length I suppose, I couldn't use them.
John
1985.5 944 GTS |
Slippery Slope Victim
The coil wire on a Carrera has to go to the coil mounted on the inner fender. On an SC the coil is mounted on the fan housing.
Hence different lengths of coil wire. Other than that..no difference. I've compared them on my Carrera & SC and see nothing different. Good Luck
MikeČ 1985 M491 |
">> The distributor boots and terminals are different."
>> >> Richard Clewett >> Clewett Engineering >> www.clewett.com >>
1985.5 944 GTS |
