coolcavaracing.com
Kroggers's Avatar
Send a message via Skype™ to Kroggers
Is there anything wrong with using stainless steel fasteners?
I am in the process of reconditioning and replacing a lot of parts on the car (winter project), including front suspension, bumpers etc. A lot of the nuts and bolts that I have removed from the car are rather rusted, and I was considering replacing most of them with ss fasteners - they do not rust, but I know they are not as strong as other materials. What is the general consensus on using ss attachments on our cars??
Pål (Paul) - The Norwegian lost in Finland...
1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!)
come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
Old 12-07-2006, 02:14 AM
FLATTOP's Avatar
Paul
Rather than going for Stainless Steel fasteners I would suggest either Nickel Plated or Zinc Coated bolts. If I am not mistaken you retain the strength of the steel bolts but have an added feature of being rust resistant. I have also found that the stainless bolts are not as dimensionally accurate as the steel ones.
I am going through the same process with my track car where all the factory bolts have been replaced by cap screws (black). Despite my stoutest efforts rust (oxidisation) eventually forms on protruding bolt heads. Hence the move to replace the bolts with zinc plated bolts.
Maybe a nut & bolt expert can cast more light.
Regards
Johan
Johan
www.almost.co.za
Old 12-07-2006, 03:49 AM
coolcavaracing.com
Kroggers's Avatar
Thank you for the info Johan, are plated bolts available from shops, or only special order??
Old 12-07-2006, 04:53 AM
Registered ConfUser
No expert here but...be very cautious about replacing suspension hardware with anything that does not meet the hardness and durability characteristics of the originals.
Mike
Old 12-07-2006, 04:58 AM
coolcavaracing.com
Kroggers's Avatar
I was more interested in replacing the fasteners for the bumpers, oil cooler, horn bracket etc - you know general stuff, rather than the core suspension hardware. For the suspension and other parts that my safety depends on I will only use original Porsche parts
But thank you for the warning
Old 12-07-2006, 05:07 AM
SS can be ok.. it depends
I wouldn't use SS on suspension though. SS is great for fan shroud strap, engine shroud nuts and side bolts, threaded rivet bolts, etc. I mostly use marine grade. Those I bought from McMaster were a lower quality but doable for the rivets.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-07-2006, 05:13 AM
coolcavaracing.com
Kroggers's Avatar
So Ronin, would the ss stuff you can get in a bag on ebay be ok for the stuff I was talking about (bumpers, oil cooler, horn bracket etc) or not?
Or should I get the zinc plated stuff instead and forget about ss fixings on my 911
Old 12-07-2006, 05:19 AM
SS cheap grades may rust?
I'd say check out McMaster for your metric items as SS w/anti-seize is real nice to work with after many yrs. For instance I'd be nervous to disassemble rusty bolts from threaded rivets after it sitting around many years. Same goes for what you mentioned. It also stays hard so you won't be rounding off any bolts or nuts.
I also use them on head stud nuts and mufflers but that requires technique or they'll come loose.
did I say I live on a sandbar, 1,000' from the ocean and 200' from a large channel?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-07-2006, 05:46 AM
coolcavaracing.com
Kroggers's Avatar
Great, thank you Ronin, then I will order in some general ss fasteners and not bother with the zinc plated stuff
Old 12-07-2006, 05:51 AM
oneblueyedog's Avatar
The main problem I'm having with SSteel is that the bolts loosen over time and I can't fish them out with a magnet. I'm using them for the engine sheetmetal. I think the heat cycling of the engine does this. When I drop the engine, I'm going back to ferrous.
78SC coupe, Silver Metallic
Old 12-07-2006, 05:53 AM
what I do is re-torque clockwise only after a few heat cycles.. then again after many cycles for exhaust and other heat cycling areas.
they never come loose after that.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-07-2006, 05:59 AM
Kantry Member
oldE's Avatar
One more thing to be cautious of: If you live in a corrosive environment, perhaps with salt on the roads in winter, there will be galvanic action where dissimilar metals are in contact. If you are using plated fasteners, the plating usually corrodes first. If your fasteners are stainless, there is a good chance whatever mild steel parts they are holding together will be the first to go.
Les
Best
Les
Old 12-07-2006, 06:44 AM
I wouldn't use stainless fasteners on any exhaust or engine part. Besides not having the same characteristics as mentioned above, stainless fasteners tend to gall when they get hot and overtightened.
Thread galling is most prevalent with fasteners that are made of Stainless Steel, Titanium and other alloys which self-generate an oxide surface film for corrosion resistance.
Thread galling is also referred to as “Cold Welding” as during fastener tightening, pressure builds between the contacting thread surfaces and protective oxides are broken. The interface metal high points then shear or lock together. This cumulative clogging action causes additional adhesion and increases the severity of the galling.
In extreme cases the galling effect leads to complete thread seizing and if tightening is continued the fastener can be twisted off or its thread stripped.
To help reduce the amount of galling produced, slowing down the RPM of screw tools will frequently reduce and in some cases solve the problem completely. As the screw tool RPM increases, the heat generated during tightening increases. As the speed and inevitably the heat increases so does the tendency for the occurrence of thread galling.
Lubricating the internal and/or external threads frequently eliminates thread galling. The proposed lubricant should contain substantial amounts of Molybdenum disulfide (Moly), graphite, mica or talc. Some proprietary, extreme pressure waxes may also be effective. Lubricants can be applied at the point of assembly or pre-applied as a batch process similar to plating. Several chemical companies offer anti-galling lubricants.
Old 12-07-2006, 06:52 AM
David's Avatar
If you're having corrosion problems and switch to stainless bolts the corrosion on the non-stainless parts will increase.
Old 12-07-2006, 07:36 AM
Somatic Negative Optimist
Gunter's Avatar
Good stuff mentioned here, especially the lube-stuff.
For the non-essential fasteners, SS is o.k. with lube.
I use Moly-graphite anti-seize on pretty well all of the nuts and bolts, SS and steel.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 12-07-2006, 08:00 AM
Banned
fastpat's Avatar
What the others have said here, plus, stainless will "cold weld" itself together in a high vibration environment. So anything threaded stainless on stainless must be put together with anti-seize compound, as should anything put into aluminum.
The best are yellow zinc plated, or cadmium plated. Second best is silver zinc plating, no third best coating. Also, you never want a lower strength piece of fastener hardware, unless it's strictly decorative, and I'd be careful there.
Old 12-07-2006, 08:14 AM
fwiw.. I have been using SS successfully in my act for over 40yrs.
and with all due respect.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-07-2006, 08:24 AM
Cordts's Avatar
I have rebuilt many british cars and use SS & grade 8 alot.. no problems with the SS.. SS for show Grade 8 for strength
1967S Porsche Targa #500317S EURO
1972 BMW 2002Tii
1967 Triumph TR4a Irs
1967 Austin Healey "Bugeye" Sprite
1966 Austin Healey 3000 MKIII
Old 12-07-2006, 08:58 AM
Grade 8 ( or 5, whatever)...does not compute and does not apply to metric fasteners. There is no "grade" for metric...only "property class".
Reference...US Grade 5 ~ property class 8.8
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 12-07-2006, 09:34 AM
Cordts's Avatar
Will .. I was simply saying that have used 8's for the British work that we have done and also used SS extensively,, with no negative's.. there is another stronger value.. 10. something.. available here in NC on special order..
1972 BMW 2002Tii
Old 12-07-2006, 10:02 AM
