Black plastic ignition ring.
Quick question, using some soap and water on the instrument panel, turned the plastic ring around my ignition a milky white.
What's that all about, and is it easy to replace? Thanks.
1964 Blue 356SC Coupe (Disintegrated from rust)
1970 Orange 911T Targa
1977 Black 930 Turbo 3.0 -1988 Carrera slant nose (Sold)
1996 Black 993 Cab.(Sold, and back in Germany)
2006 Slate Grey Carrera S coupe
Old 12-07-2006, 01:56 PM
Drop it in some black RIT dye mixture overnight. Pick up some red dye and Wite-Out and you can rejuvenate your heater control knobs while you're at it.
The little things can really dress up the 911 office.
Brian
Old 12-07-2006, 02:39 PM
randywebb's Avatar
I wonder if shoe dye would work well?
also could try just treating it with a plastic & rubber treatment
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 12-07-2006, 03:00 PM
Eric Coffey's Avatar
Scotch-Brite pad and some Wurth Satin Black did the trick on the last two "chalky" ignition bezels I had.
Old 12-07-2006, 03:30 PM
Brian
Is it easy to get off?
Old 12-07-2006, 05:18 PM
A broad black felt-tip pen might work.
I've only done the red dye and and Wite-Out on my heater control knobs. My car's ignition trim looks great.
Like Randy said, liquid black shoe polish should work for that plastic trim piece, too.
Brian
Old 12-07-2006, 05:34 PM
Nine9six's Avatar
What Eric said...
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 12-07-2006, 05:42 PM
I had milky white ignition ring and door lock rings. I accidentally discovered that Eagle 1 Leather Care Creme Conditioner brings them back to their pristine, supple state.
It's a one time application and they've never turned milky again.
Silver '87 Targa
Old 12-07-2006, 06:01 PM
Todd Simpson's Avatar
Indeed it will.
Old 12-07-2006, 06:14 PM
vroom vroom
Send a message via AIM to MaquinaVerde
I just did this a couple of days ago. Vinyl/Plastic interior dye spray from your generic auto parts store on the two plastic parts and a few coats of matte black lacquer on the metal top ring will make it look like new.
Matt
'70T
Old 12-07-2006, 06:22 PM
Nitrometano's Avatar
to take it off just lose it like a nut.
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 12-07-2006, 08:45 PM
Re: Black plastic ignition ring.
Unscrew it, throw it in the trash and buy a new one. A new replacement cover will cost less than any cleaning solution you're planning on buying. If this is for your MY96 993 then you want Porsche part no #911-613-160-01-70B.
Old 12-08-2006, 12:40 AM
