Guest
Posts: n/a
Valve adjustment...I"m stuck
Everything is off. The rotor is going toward the no 1 plug wire and also toward the mark on the distributor. Also, the crank pulley mark is pointing to a mark on the block, BUT I DO NOT SEE "Z1" Anywhere! I cannot fit the gauge into the No1 space at all. This leads me to assume I might not be lined up. It's not that there's a Z1 somewhere else, I can't find it anywhere. Just the marks on the inside lip of the pulley.
Should I stop and put it all back, or adjust it this way? ------------------ Kurt B 1984 911 Carrera Cabriolet 75 914 1.8 |
Guest
Posts: n/a
Just finished with mine, no Z on my crank pulley either. Just use the double slash and point distributor to #1. Make sure both exhaust and intake rocker has a little slack and you're there. Next move to the single mark and so on and so on.
Guest
Posts: n/a
I know on my 2.7l there is the Z1 and a 5 degree mark. So if yours is like mine and there are two marks relatively close together the one on the left while facing the engine is Z1.
Guest
Posts: n/a
Kurt,
Did you clean off the periphery of the crank pulley while looking for Z1? Was there clearance at both valves when dist. rotor was pointing to #1? According to the pics in the Bentley manual, there are 4 marks 'grouped' for cyl. # 1 ... appearing in this order scanning left to right: 5 deg. After TDC, Z1 or TDC, 30 deg. Before TDC, 35 deg. Before TDC. There are also single marks 120 and 240 degrees after the Z1 mark. ------------------ Warren Hall 1973 911S Targa |
