if you got to choose1 wevo Shifter or wevo gateshift
which one? budget only allow wevo shifter or wevo gateshift.
for 915 fast road use, some track :D |
shifter...
I have the shifter, its a great improvement well worth the money. I vote for the shifter.
which color or style did you guys get?
I have the long knob which is silver on a Wevo lever which is black. The shifter alone will change the way you look at and drive a 915 tranny.
thanks!
Shifter.
It will also be much easier to install than the gateshift kit, which requires dropping the transmission/motor. I've got the black shifter with long silver knob. As above, it's tremendous. http://forums.pelicanparts.com/uploa...1164813472.jpg If you can, stretch to upgrade your motor/tranny mounts, and shift coupler too. The three together are a dream. |
You don't have to drop the engine or tranny to add the gate shift kit. A lift will make it easier.
All black WEVO shifter....I have a silver RENNSHIFTER in my 901 trans for the 914/6.....
motor and tanny mount is that the one that pelican sell? the wevo ss mount? semi solid? is that good for street or optimise for track use? cheers |
| All times are GMT -8. The time now is 11:24 AM. |
