1970 911E heat exchangers
First thanks to all the good advice on removing the heat exchanges. The MAPP O2 torch did the trick, only one broken stud and it is still protruding about a 1/2 an inch so I think I'll be able to get the stud out.
While removing the HE's to track down an oil leak, I think it is the cooler, I noticed something odd about the HE's. Th PO thought he had put on SS HE's but once I got them off I noticed that the HE itself was SS or some other non corroding material but the connections to the head and to the muffler seem to be steel and at least on the left side corroded. I can move the pipe inside the HE. It does not look like there is any way to fix this but I was wondering if this was a common thing, seems odd to mix SS & steel?
Let em know and I can try and post some pictures.
1989 Cabriolet
1970 911E Sold
Old 12-11-2006, 11:52 AM
randywebb's Avatar
I think that was done by some co.s to make a cheap version (knock-off) of the SSI...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 12-11-2006, 12:18 PM
Bill Verburg's Avatar
Actually, early on, the heat exchangers were designed w/ mild and ss as a safety feature, SS pipes and mild boxes meant that the outer portion would rust before the inner, preventing an unnoticed ingress for CO gas.
Don't know what you have there but do replace w/ true ss as used in SSI's
Bill Verburg
Old 12-11-2006, 12:31 PM
randywebb's Avatar
wasn't that in the '60's tho (?)
Old 12-11-2006, 12:45 PM
right up through at least the early '70s, '72 for sure, maybe '73, the factory didn't start using all ss(still a lower grade outer) til later, probably '75. I know that in '76 it was all ss
The only reason I think '75 was the transition year, was that was the first year of the smog exhausts outside Ca.
Bill Verburg
Old 12-11-2006, 12:50 PM
Thanks for the info. What is strange is that it seems the outside is SS adn the internal tubes steel? Once I get teh oil leak fixed it will be time for new SSi
1989 Cabriolet
1970 911E Sold
Old 12-11-2006, 12:53 PM
It is strange and most likely a cheaper aftermarket exhaust. SSI are a quality product
Bill Verburg
Old 12-11-2006, 12:57 PM
randywebb's Avatar
Thanks Bill - we probably need a heat exchanger evolution thread..
I may be thinking of the very early "Kill-ya-Dead" design...
Old 12-11-2006, 03:54 PM
