-   -   Weber 40 Rebuild Question (http://forums.pelicanparts.com/porsche-911-technical-forum/319492-weber-40-rebuild-question.html)
jbell959 12-10-2006 08:29 PM
Is it possible to remove these tubes? One of mine is bent and I would like to straighten or replace it while they are apart (This picture isn't my carb).
http://forums.pelicanparts.com/uploa...1165811342.jpg
bede 12-10-2006 10:25 PM
Just tap it straight with a soft hammer it will be fine Cheers
jbell959 12-11-2006 05:33 PM
It got bent pretty bad in shipping so I'm affraid it will be kinked pretty bad if I try to straighen it.
Is there any way to remove and replace them?
limble 12-11-2006 06:31 PM
Can you find a rod that is the same diameter as the inner diameter and gently tap it in? Silicone or oil so it comes out easily. Never tried it just a thought.
bede 12-11-2006 06:47 PM
It is not able to be removed easily as it is burred over underneath the base.It is only a breather it wont kink & as long as the air cleaner base will go back on it can be bent a little & will work fine.Cheers
