AKA SportsCarFan
Battery tender: danger or paranoia?
Forgive me if this is a stupid question....
I have put my 88 911 down for its long winter nap & I am considering the purchase of Porsche's battery tender (from our host). My concern: is there any danger (fire or other) in leaving the battery tender plugged into the cigarette lighter all winter? I am primarily concerned because it is a rather old car, with rather old wiring. I realize it can also be attached directly to the battery, but I am worried that one of the clips might slip off, or come off if someone accidentally kicks the wire walking by it in the garage. Thank you in advance for your advice...& for not laughing. Doug P.S.: "It's not paranoia if everyone really is out to get me."
Doug Miller 1988 Guards Red Carrera |
Platinum Member
Minimal current flows from the tender to the battery (that is why it is also called a 'trickle charger') so I doubt the tender would be a problem. With or without the charger, the wiring is still connected to the battery.
If you are concerned about the wiring, disconnect the battery from the car, and hook up the charger directly to the battery.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
AKA SportsCarFan
Thanks...I ordered my battery tender from Pelican today.
Doug
Now in 993 land ...
It's too late now, I suppose. But if you really store it for an extended period of time, I'd just pull the battery, set it on the work bench and be done with it. Then charge it before you put it back in spring and you are all set. Cheap, easy and safe.
George |
Automotive Monomaniac
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
Now in 993 land ...
So, how much do batteries cost? Why are people obsessed with tickler chargers that cost as much as a whole new battery?
![]() But seriously, call me paranoid, I usually disconnect the battery on any car I store for longer periods just for safety. If you have a sharp toothed critter get in there and create a short, you are in for a garage / house fire, that you could have easily avoided. You can store a fully charged battery for 1/2 a year no problem when there is no load on it. It should be charged when you start out. The reason people put the battery tender - in my book - is to keep up with the small drain the radio, clock and computer, if so equipped, put on the battery. Makes sense if you store 4 weeks at a time on a computer equipped car, but not on an older no brain car that you put away for 6 months. Just my two cents. I better go drive the 993 to work tomorrow to tender the battery. ![]() George |
Wider is Better
Wider is Better |
I use a trickle charger daily. It is nice knowing my battery is not an issue - they work great.
AKA SportsCarFan
Thanks for all of the comments. I also read a couple of other posts about battery tenders. The instructions & some of the comments I read mention using the tender in a well-ventilated area.
My concern is how ventilated the battery has to be. I have a battery vent kit installed & the car sits in a rather large 3-car garage that is opened/closed several times a day. However, I do have a cover on the car. Is that ventilated enough? If not, I could pull back the front of the cover & possibly even pop the hood open a bit. Is it safe to use the battery tender with a battery vent kit, the hood closed & a car cover? Thanks in advance for your comments.
Doug Miller 1988 Guards Red Carrera Last edited by FastCarFan; 12-17-2006 at 06:02 PM.. |
Author of "101 Projects"
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Doug - you're fine - don't worry
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
"My concern is how ventilated the battery has to be."
During the charging process, lead-acid batteries produce hydrogen gas which is flammable. It can cause the battery to explode if an errant spark is generated (as in disconnecting "live" charger leads from it or by creating incorrect polarity connections). I haven't heard of explosions extending beyond the battery case, so I think the garage structure is pretty safe, but you don't want acid splashed onto wiring, paint, plastic and other car parts. Sherwood |
OT
XC Battery Chargers provide longer battery life by independently controlling the charge profile for each battery bank. The XC is the first “smart” charger that can charge up to 3 different battery chemistries simultaneously, a microprocessor-controlled multi-stage charger with settings for flooded, gel, AGM, lead-calcium or custom battery types. This unique multiplex design means that boaters can choose the optimal battery type for each application on their boat without concern about battery damage from either under- or overcharging. Designed for marine use, they are versatile enough to be used in a wide variety of conditions and locations. Auto-ranging AC input voltage capability (100-260VAC) makes traveling abroad and handling poor quality power a breeze. The easy-to-read digital display is invertible to accommodate either horizontal or vertical installations, and can be detached and mounted wherever needed. An optional intelligent shunt provides a simple “fuel gauge” capability that displays amp-hours consumed from a selected battery bank. Includes battery equalization setting and independent temperature compensation for each bank, unique drip-proof design. Can charge "dead" batteries with voltage below 6V. 4 1/4" x 9 5/8" x 14 3/4" - Number of Outputs: Three - Automatic Functions: Smart multi-stage charging and temp. sensing - User Selectable Functions: 2 stage, 3 stage, or custom charging, AGM, PBCa Gel, or flooded battery type on any channel - Status Indicators: Charger status/ charge current lights - Temperature Compensation: 3 independent channels (one sensor included, additional sensors required) - Input Wiring: M6 Studs - Output Wiring: Hardwire - Safety Features: Fuse-less reverse polarity protection, ignition protection, over-voltage/over-temp - Remote Available: Invertible/detachable digital remote panel included - Approvals: Meets CSA 107.2, UL 1564, UL 1236 including Marine Supplement, Ignition Protection, EMC FCC Class B, CE - Warranty: Two years XC Multi-Chemistry Battery Chargers XC5012 Charger, 50A, 12V 7779861 804-5012 $680.00 Suggested Popular Accessories - XANTREX Battery Temp Sensor 7779903 $39.99 XANTREX Remote Display 7779911 $150.00 XANTREX Easy Shunt 7779895 $130.00
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Priced-out of Porsches.
I guess I'm paranoid, too....The last time I used a trickle charger on my small Odyssey battery, it was very warm (posts were hot) to the touch. Is this considered normal? I haven't used the charger since then for fear of exploding the battery or starting a fire in my wiring.
Mike SoCal |
I have an 800 mA Deltran battery tender connected to my car. Its very safe and wont overheat your battery. It comes on when the voltage drops bellow a certain point and turns off at another point. This is the best way to keep your battery topped off during the winter. It produces a slow mild charge only when needed. They run around 25 bucks.
95' Mercedes E300 Diesel (Azure+Sodalith Blue) 88' Porsche 911 Targa (FOR SALE) (Guards Red) |
Please do not confuse trickle chargers and battery tenders, they are two different devices. A Tender reads the voltage and only comes on to top off then shuts 100% off. A Trickle charger remains on pushing current all the time. Tenders, Good. Trickle chargers, not good.
A good battery costs 2X what a Tender costs. The time spent finding out the battery is crapped out and getting another one rather than driving the Porsche is 10X the cost IMO. |
I just hooked up my $9.99 HF battery float charger yesterday - set it and forget it. See you in April.
Regards,
Joe 85 Carrera 64 Honda Dream - for sale 71 Hodaka Super Rat - keeper |
AKA SportsCarFan
Thank you everyone. As always, I really appreciate the advice.
Happy holidays, Doug
