strut brace is great!
so i just put in the weltmeister camber strut brace.
I had to shave some material off one of the brackets to get the hex head bolts to fit in correctly. but wow..its a nice change! really keeps the front end down tight. now i just have to keep the back end from slidding out ![]() but yah....my story was i put in new sport bilsteins, got it aligned and corner balanced and the car still felt mushy. I figured it was cuz of the big tires i've got on there. either way it didn't feel right so i figured the strut brace would help....sure enough it did make a difference. id recommend it. its only $200....good investment. |
really? Ther towers struts brace make that much diff? You mean on an agressive turn?
Fat butt 911, 1987 |
yah....on aggressive turns...it keeps the front end tighter.
19 years and 17k posts...
I've always heard that they don't make much, if any discernable difference. Interesting...
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
i swear im not imagining it....haha...
I have the twin tube Rennline unit. Believe me, it works.....
cheers, Phil 84 ROW Carrera (guards red), A/C delete, Fuchs 7 + 8 x 16, Koni Adj. F+R, sway bars 20F 22R. turbo tie rods, Strut brace, brake cooling kit, C/F Recaro GT3 copies. |
I think one overlooked aspect of strut braces is that it will help keep your tub straight for the long run.
Ken Justice 1985 Carrera (Ruby II) 1973.5 911T CIS (Ruby, gone but not forgotten) 2004 Buell Lightning (aka Elbow-Crusher, crashed) |
Does it do anything for the dashboard shake over bumps by stiffening the structure?
Art '75 911 US Carrera #390 '74 MGB, AH 3000 BN7 V8, '65 Mustang Fastback, 66 bronco U13 |
"O"man(are we in trouble)
Is it necessary to do an alignment following installation??
I'm looking at the twin bar from Rennline and was wondering the same thing about alignment, they say on their website, you do not need to do an alignment. It is not effected. Curious what you all have done. |
As long as you dont undo all the bolts on the shock tower, only the 2 required (for my installation), no alignment is necessary.
More experienced guys I'm sure would shed more analytical advice on this. Phil
I am going to install my strut brace, do you tighten to pull struts or loosen to push the struts?
Thanks, Eddy |
I too fitted a brace recently.
Yet to do some decent miles but initial thoughts indicate a noticiable difference on fast'ish choppy corners. It now holds such corners tight as. I think too it's a little more pointy through corners, hence I feel a slight reduction in understeer since fitting.... Another plus is driving over level crossings; the car doesn't seem to 'jiggle' so much anymore. So for $200, I feel it is worth adding a brace.
1987 911 midnight blue, euro spec, 7&8 Fuchs, SW chip 2003 Fiat Multipla Don't blow a seal......literally. |
I installed my Elephant Racing Brace just before an alignment, and let those guys set the tension. I felt a huge improvement. But I can't really tell you how much was done by the brace cause it was after I lowered the car, etc, etc.
Bill 997.2 |
THE IRONMAN
You install it with some (light) tension on the bar...like you want to pull on the strut tower...
1984 911 CARRERA RUBY RED TARGA SW CHIPPED-BURSCH CATBYPASS MONTY FREE FLOW EXHAUST <IN GAS WE TRUST> |
Automotive Monomaniac
I have had the Weltmeister for a couple years - and yes they (any strut brace for that matter) make a difference.
I have tension on mine for a bit more negative front camber.
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
I put one in and really don't feel much difference. It does look good
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
you've really gotta drive it hard to notice a difference...but it is there....
so can i just screw a couple threads one the welmeister to get some negative camber? or do i need to bring it to a shop
You should notice about $200 worth of difference.....small money, small difference.
I had an immediate improvement, but then I added new tires, alignment, and corner wieght at the same time so I've never really known how much was which part.
Steve 87 Targa |
