993 HE's on a 3.2
I've got these coming soon.
Who can tell me what diameter heat tube/hose I'll need to connect the heat to a heat backdate setup? thanks, Phil
cheers, Phil 84 ROW Carrera (guards red), A/C delete, Fuchs 7 + 8 x 16, Koni Adj. F+R, sway bars 20F 22R. turbo tie rods, Strut brace, brake cooling kit, C/F Recaro GT3 copies. |
What do you hope to gain or just for looks?
Joe |
Oh, you know, these cars are butt ugly so I thought I'd make the arse end under the bumper look really nice to compensate.
Other than that I just thought I could p!ss some good cash up against a wall (LOL!) Seriously Joe, I've researched this for a few months now and there is divided opinion about this setup v SSI's. I'm planning further tweaks like cams, heads/valves, TB bore in the not-too-distant future. It also gives headroom for a 3.6 further down the track if I decide with some gains in the meantime. A bit cheaper than SSI's and arguably better gains on the track, which is where I plan to do a lot more driving. So about my thread, do you know the ID tube for the heat?
PRO Motorsports
The inlet O.D. is 2 7/8th's, so a 3" I.D. hose should work as a sleeve.
The outlet is oval. It's 2 1/4 o.d. by 2 7/8ths o.d.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
I think I screwed up.
I bought some of this stuff from Aircraft Spruce in the 2.5" ID: http://www.aircraftspruce.com/catalog/appages/scat.php I saw this in athread for heat backdate somewhere. Tyson can this be made to work with some ss 2.5" od tube as an adaptor socket for the air in? What about the air out to the flapper boxes? Phil
PRO Motorsports
That might fit over. Just depends how much it can stretch.
The stuff you have will work for the outlet, IIRC. But you'll need to adapt it down to go into the flaper valves.
