-   -   yet another "It won't start" thread.. my 1982 911SC and help needed. (http://forums.pelicanparts.com/porsche-911-technical-forum/319968-yet-another-wont-start-thread-my-1982-911sc-help-needed.html)
Blanco 12-13-2006 03:17 PM
Esteemed gruppe!!
My old Permafail was going in/out intermittently and was confirmed by swapping out with a good one.
I decided to go with an MSD 6A for ease of installation and after reading tons of "no spark/start" threads.
I changed the green wire since it was cracked and frayed. I also changed cap/rotor with spark plugs since it was due.
All was good with the world after I changed the system out to MSD. It cranked up fine and I drove it down to the gas station for a fill up.
I got back home and proceeded to wrap the rest of the wires with electrical tape.
This is where the problems started. It will NOT crank now.
:mad:
What would cause a no start symptoms when I began to zip up the wires into the loom??? :confused:
Thanks,
Alex
Nostril Cheese 12-13-2006 03:27 PM
Check the yellow wire in the loom. I believe this is the signal wire from the key to the starter solenoid.
dweymer 12-13-2006 03:31 PM
A loose conection? A short induced by the movement(this happened to me; car drove fine for 8 miles stop start red lights etc. then I come to a light, and poof, no more magic smoke, just died) I shorted my pertronix out.
Blanco 12-13-2006 03:34 PM
Originally posted by dweymer
A loose conection?
That's where I'm headed. Did you ever find out where your loose connection was?
I'm also checking the yellow wire that Nostril cheese suggested.
dweymer 12-13-2006 03:40 PM
I was actually a small spot of bare wire right as it goes into the spade connector. Use heat shrink on all joints!
Check all your fuses to see if one blew.
