Harness Bar Guide Loops?
I am looking for the harness bar guide loops to weld onto an existing harness bar - anybody know of someone that can source these?
The only luck I have had is CDOC but they do not sell them - all other sources have turned up empty. Thanks -
Jeff Last edited by NoLift911; 12-14-2006 at 01:54 PM.. |
Why not just get some small diameter rod material make them?
Don 24 Cayman GTS - GT Silver 23 Cayman GTS - Arctic Grey - Sold 97 993 Coupe - Arctic/Black - Sold 13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue |
Make your own. Take some steel rod, bend it into the right shape, clean off the paint where the ends will go, and weld it on.
I fretted about this, but it turned out to be simple. Here is a picture of one I did to hold in place one of the straps that attach the bottom of my window net. It is wise, I think, to do this. A right side impact will pull on the belts at the bar quite a bit as the seat leans over to the right. I prefer to use clip or bolt-in ends on my belts, for ease of removal and because there is less chance of point loading on the edge of the webbing. But that is a lot more work: welding in a threaded tube through the bar to serve as the anchor point (you never want to attach something to a tube by drilling through the tube and using a long bolt). Walt Fricke |
Yeah - thought about this and looked for a local supplier in my area for the rods and was headed down that path. It was just easier in my mind to buy these if avaible - if not I will make my own. I was also looking for some gussetts as well and ca make them also but again looking for the quicker way
Thanks -
Jeff |
Gussets are easy to come by pre-cut. Lots of roundy round suppliers sell them. Like aa-mfg.com.
