-   -   unusual electrical problem (http://forums.pelicanparts.com/porsche-911-technical-forum/320159-unusual-electrical-problem.html)
roadhog 12-14-2006 06:37 PM
Tonight while driving my 80 SC an electrical problem occurred.Intermittently the seatbelt light would come on the tach would jump & the headlights would get very bright.I think it
burned out the high beams.
Has anyone experienced this problem?
Green 912 12-14-2006 07:14 PM
Check the voltage output from the alt. Might have a bad regulator or bad connector in the charging system.
john walker's workshop 12-14-2006 07:14 PM
bizerk voltage regulator.
Early_S_Man 12-14-2006 07:14 PM
Failing Voltage regulator ... high Voltage spikes!
Check/monitor your system Voltage ... plan on getting a new Voltage regulator, soon!
Patton 12-15-2006 05:52 AM
The sooner the better. The more you run with those symptoms the greater the risk of frying additional electrical systems (expensive).
roadhog 01-20-2007 05:59 PM
After reading Jim Thorusen's troubleshooting guide on this site I removed the alternator and found the D+ connection to the voltage regulator loose.The regulator looks at D+ to determine excitation current in the alternator.If the regulator sees low or 0 voltage at D+ it increases excitation current which raises output voltage.Anyway I put the alternator back in and drove several test miles with no voltage spike problems.
Note;my alternator was a Valeo with internal regulator.
Thanks for all the help!
