unusual electrical problem
Tonight while driving my 80 SC an electrical problem occurred.Intermittently the seatbelt light would come on the tach would jump & the headlights would get very bright.I think it
burned out the high beams.
Has anyone experienced this problem?
76-911s 80-911sc
Regards Lester
Old 12-14-2006, 06:37 PM
Green 912's Avatar
Check the voltage output from the alt. Might have a bad regulator or bad connector in the charging system.
Old 12-14-2006, 07:14 PM
bizerk voltage regulator.
206 637 4071
Early_S_Man's Avatar
Porsche Crest
Failing Voltage regulator ... high Voltage spikes!
Check/monitor your system Voltage ... plan on getting a new Voltage regulator, soon!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Patton's Avatar
The sooner the better. The more you run with those symptoms the greater the risk of frying additional electrical systems (expensive).
Patton
No Porsche at the moment but give me 6 months and then......
Old 12-15-2006, 05:52 AM
After reading Jim Thorusen's troubleshooting guide on this site I removed the alternator and found the D+ connection to the voltage regulator loose.The regulator looks at D+ to determine excitation current in the alternator.If the regulator sees low or 0 voltage at D+ it increases excitation current which raises output voltage.Anyway I put the alternator back in and drove several test miles with no voltage spike problems.
Note;my alternator was a Valeo with internal regulator.
Thanks for all the help!
76-911s 80-911sc
Regards Lester
Old 01-20-2007, 05:59 PM
