Throw it on the ground!
Anyone use Valvoline Synthetic Gear Oil?
OK, I've decided to go with a gear oil change to synthetic in hopes that it will improve cold shifting. PO records indicate last gear oil change was 35,000 miles ago with 80W-90 dino.
Can't find Mobil 1 or Red Line on the shelves locally, but NAPA carries Valvoline 75W-90. Anyone have any experience with Valvoline? Can't imagine there would be that much difference between these brands but this is why I ask.
Thanks!
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 12-15-2006, 05:35 PM
I would like to know the same thing.
87 Carrera Cab GP White
01 740i Sport
03 Honda Odyssey
Old 12-15-2006, 06:14 PM
cygtoad's Avatar
I have used it in my 87 G50 with good results. I put it in three years ago which was about 15K miles ago.   I just changed it again this fall and there was much less fuzz on the magnetic plug than I had seen with my initial change, but I don't know how many miles that was.
I can't really give you a comparison on the cold because I have run this stuff in my tranny since I got it 4 years ago. But I have run it into December in NH and never had trouble shifting gears.   Hope this helps.
_______________________
Unless you change your course, you are likely to end up where you are headed.
'87 Carrera, Black on Black
Old 12-15-2006, 06:55 PM
FYI, here's the factory fill....
http://www.lufteknic.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=Mobil75-90SHC&Category_Code=lubricants
brant giere
2005 996 cup
1991 964 euro cup (Larbre #28- race
1987 carrera 3.2-street/de car
1962 Austin Healey 3000
Old 12-15-2006, 06:57 PM
Two thumbs up for Mobilube 75W-90 SHC gear lube from lufteknic.com.
1987 Carrera 3.2
Old 12-15-2006, 08:16 PM
3.4 Bigger is better
88-diamondblue's Avatar
I used Mobil One synthetic gear lube and would not hesitate to use Valvolene Synthetic for a moment. the quality is so close that you would need to do a side by side study to see if there is any difference in wear. JMHO
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 12-15-2006, 09:40 PM
Thanks! I picked some up today and will prob do the change next weekend. Will report back on cold shift impact. Currently on really cold AM's I often cannot get into 1st, 2nd or Rev. I have to initally it into 3rd and once I do I can then get into 1st or Rev to get moving. Once I get warmed up it shifts perfectly.
Mark
1987 911 Coupe
Old 12-16-2006, 09:27 AM
