911 sc engine stumble
A friend of mine has a 78 sc that has an engine stumble at 2200 rpm. I think it started about the time that a lot of ignition system work was being done. The distributor was rebuilt by a racing group, could they have done anything in the rebuild of the distributor that would cause this? Any other thoughts? Thanks.
I can think of a lot of things that could cause this.
Injectors, cap rotor, spark plugs, wires etc. or maybe the timing? Just throwing ideas out there.
1982 Porsche 911SC Coupe - Factory Short Shift |7:31 R&P in AL case | Toyo RA1 Tires | Corbeau TRS seats | M&K 2 in 2 out muffler |
all of those things have already been looked at, timing, injector flow, new wires, plugs, rotor, cap, etc.
coil? ground straps?
1980 911SC #99 track car, 993 3.6, 50 PMO's 2019 Ford F150 da dragger 2015 MB SL400 wifey DD 2008 E93 M3 DD 2007 E60 530 wifey winter beater |
It could be something as simple as a plug connector not seated on a spark plug.
After checking that, pull your plugs to see which one is black compared to the others. |
