Diagnostics using Noises
I can't recall a thread specifically on using odd noises as diagnostics, so I'll start one...
Rattling from rear like chains being dragged over a metal garbage can -- engine chains/tensioner problem; STOP driving immediately Small pops or clicks from front - near dash -- no problem; the metal is expanding or contracting rel to the glass in the instrument binnacles Moan or howl from rear -- 1. kid in back is being burned alive because you removed the insulation near the firewall to save wt.; use earmuffs & continue driving or 2. rear wheel bearings are about to blow up -- replace/repack Rougher noise from rear than the moan or howl above - varies with speed -- CV joint problem; Limit driving and check immediately - loose CV joint will destroy the bottom of the car Backfiring -- try to determine if it thru muffler or is out the intake -- {need to break this down by type of Inj. systems} |
SCrrreeeeming howl from Right side - remove passenger
| All times are GMT -8. The time now is 08:59 PM. |
