rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
I have Kolbenschmidt. Should I be bummed?
I just found out from my topend shop that I have Kolbenschmidt-- not Mahle-- P&C on my SC. What's the downside for a street car?
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 12-22-2006, 02:48 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
I found the same thing for my track car, and I'm putting them back in. I pulled the P&C's together without removing the P's from the C's. I had no compression or oil consumption problems before the teardown. I'm just replacing bearings, rod bolts, head studs, etc., before the racing season. Worst case, I'll be forced to replace them later. At least the rest will be done.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 12-22-2006, 04:38 PM
I think it depends on the reason you are rebuilding. If it is just a top end job, say for Dilavar head studs like mine and your leak down was good then I do not see a problem doing as Zoanas and I did and remove the P&C's as a unit and put them back on. If the motor had bad leakdown or greater than say 150K miles I would source new P&C's
Richard Lane
1978 911SC
1973 "Clean" RS clone
Old 12-22-2006, 05:37 PM
rs6er's Avatar
The top end was because of 7 broken head studs. My car only has 69000 miles. I am the original owner.
John
Old 12-22-2006, 06:48 PM
chrisp's Avatar
Had mine re-ringed and the cylinders refinished. All is well.
'83 SC
Old 12-22-2006, 06:52 PM
the the is offline
I remember reading some downsides to the KS pistons, but it was so long ago I'm not sure I am remembering correctly. It seems that for a variety of reasons, though, most people prefer Mahle. I think one of the issues with KS was sometimes they tend to be more noisy than Mahle, i.e. piston slap type noise, esp. during warmup?
Maybe try doing a search on this board for more info, there may be something.
Old 12-22-2006, 07:21 PM
There is a big thread on Mahle v. KS... in the engine building forum.. Read what you want into it. I found out I have KS in my SC and this thing runs really well for 140k miles, but I feel like I am bummed too because of what I have read. Thing is, if you come from a 944 or 928 background, all the blocks are Alusil, and those guys have been dealing with this stuff forever. I was one of those guys too. There is much to learn on the Rennlist forums about Alusil. This is one occasion that the waterpumpers can give back to the aircooled boys.
I have successfully reringed a 944 and a 951 that were really fantastic runners. In my eyes the jury is still out.... when the time comes I will be considering reringing my KS if they are in spec.
'82 911
previous:
'86 951
'72 914
Old 12-22-2006, 08:23 PM
I had and rerang them with great luck until I turbo charged it and over boosted. i would put them back in and don't worry about it
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 12-23-2006, 04:55 AM
