Is there a high-quality headliner for 911s?
Has anybody created a high-quality headliner for 911s--something other than that horrible perforated-vinyl beige thing that is on-so-period-correct but in fact is oh-so-WalMart?
I'm about to remove my glass to put in Lexan, and it suddenly occurred to me that though I did the headliner 12,000 miles ago, I've hated it ever since. Now's the time to do it right...
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 12-23-2006, 02:50 PM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
what does a 911 look like without it? I would think all cleaned up it would look ok, anyone have pics of this type of setup?
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 12-23-2006, 02:53 PM
Well, what it looks like without the headliner is the inside of a steel bucket with--in my case--all the sunroof mechanicals bare-ass naked and a bunch of spotwelding and stuff that whoever did it knew the world would never need to see.
Not a pretty sight.
I'm lookin' for Ultrasuede, not iron.
Stephan Wilkinson
Old 12-23-2006, 02:56 PM
Gearbox's Avatar
Not sure what you are going for, but I'm sure for enough money, Tony at Autobahn could make you a headliner out of amy material you want, velour, velvet, cordaroy, leather, or what ever floats your boat.
1971 911S, 1974 914 2.0, 1999 Boxster, 2003 Boxster, 2008 Cayman S.
www.TheLolaRegistry.com
"When you think you are in full control, you're just not going fast enough."
Old 12-23-2006, 03:02 PM
dtw dtw is offline
GAFB
Steve,
I'm sure if you picked out a material, Tony Garcia @ Autobahn Interiors would happily stitch up a headliner for you at a fair price. He might even be able to source something for you. The only problem I see is being able to buy one headliner worth of material without being compelled to buy a whole bolt...
Several BMWs
randywebb's Avatar
you might try Alcantera! I'd still use the holes as that helps reduce air pressure differentials on either side
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 12-23-2006, 03:27 PM
Gator skin.
Old 12-23-2006, 03:41 PM
356racing's Avatar
You can also order the headliner in black from Autos. Still vinyl but it does't jump out like the off white ones do.
Old 12-23-2006, 03:49 PM
Eric-325I's Avatar
Re: Is there a high-quality headliner for 911s?
Did you find replacing the headliner to be the nightmare people speak of?
Eric
'79 SC Silver over Black... Sold
Old 12-23-2006, 04:42 PM
pwd72s's Avatar
Good advice. The holes breathe the air that flows out through the roof vent that is just above the rear window...
Old 12-23-2006, 04:45 PM
Air Medal or two
afterburn 549's Avatar
I used a black one from our host, I think with any you need to warm them up , iron them out b4 starting..I know black is incorrect for my year.....but it is mine.
start @ the front, leave plenty of green, work your way back. Order new clips- save your old ones and have some clothes pins too...you will need the extra clips while you are snorting tugging....dont get in a rush
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 12-23-2006, 05:10 PM
Shaun @ Tru6's Avatar
Stephan, when I refinished the interior of my Targa (RIP, delivered her today), I bought 6 yards ($65/yard!) of black ultrasuede for anything below the beltline; above got new vinyl. BUT, I found that it fades in direct sun and after a year my door panels and bottom half of rear deck were a dull brown. I've still got the interior and plan on using an SEM vinyl dye (lightly sprayed) or may go with a leather dye (roller) even though it's synthetic.
Besides UV, something else to think about is that ultrasuede/alcantera also may be too heavy to be a headliner.
So whatever you get, make sure it's UV secure. Perhaps a marine variant that's designed to be out in the sun as much as my open top interior was? If you know of a UV protectant that you can spray on, send me an email and I can get some of mine to you.
Tru6 Restoration & Design
Old 12-23-2006, 05:13 PM
As for the pressure differential, I'm eliminating the rear-of-roof air vents anyway, with a faired-in rear window (Lexan) that eliminates that aerodynamically dirty step. But thank you all for the leads.
And as for Eric's question about replacing the headliner, no, it's not a nightmare at all, assuming you have all the glass out. Pretty straightforward.
Stephan Wilkinson
Old 12-23-2006, 05:30 PM
randywebb's Avatar
just a few days ago I saw a pic of a 911 (was it an R?) that had red crushed felt sprayed on the interior roof instead of a headliner - tried to find it an post but failed. idea might be worth it for some folks
Old 12-23-2006, 06:51 PM
Dan in Pasadena's Avatar
Couldn't you just carefully take down your current headliner, buy whatever fabric pleases you and take it to a decent upholstery shop and have them use the old one as a pattern for the new one you want? Seems like it would work to me as long as you don't tear up the old one.
Oh...and the old vinyl one? It would stretch intentionally to aid in a tight installation. I'd try to get that same ability in whatever new stuff you pick. Good luck. Let's see pix of whatever you go with.
Dan in Pasadena
'76 911S Sahara Beige/Cork
Old 12-23-2006, 07:10 PM
Bland
unclebilly's Avatar
Not a pretty sight.
That sounds like my car... no headliner - looks like arse.
I got a set of seats recovered in black Ultrsuede and they look awesome. I think I'm going to go to the same upholsterer and have the headlined done in ultrasuede too. I bet it will cost under $200.
Old 12-24-2006, 07:10 AM
goldgunner's Avatar
Steven - the headliner I purchased from this company in Stuttgart can only be described as of amazing quality:
http://www.cabrio.de/
Jim
1980 911SC - 2nd Rebuild in Process - 2005 Porsche Cayenne Turbo - 2013 VW R
________________________
2000 BMW X5 - 1996 BMW 530i - Toy 4 Runner (x2 or 3) - 1987 Toy Supra - 1988 Honda Si - 1984 El Camino Super Sport - MGA - MGB - Fiat 124 Spyder - Fiat 128 Wagon - 1962 Karmann Ghia - 1951 VW - 1953 Willys Jeepster w/Chevy 286 - 1995 Volvo 960 - 2006 VW GTI
Old 12-24-2006, 08:48 AM
911 user
Milu's Avatar
How about white wool by West of England. Used to be used on a lot of luxury cars.
Where once the giants walked now Mickey Mouse is king.
My other car is also a Porsche.
Old 12-24-2006, 08:59 AM
randywebb's Avatar
glued on red headliner as seen on 911R #11; photo from Ernie Wilberg's site, http://www.pbase.com/911r/image/23364447/original
Old 12-24-2006, 11:07 AM
My previous DIY HL kit barely provided any extra material to overlap all around - maybe not typical now as that was a few years ago.
I'm with Dan in Pas. That's what I did. Find a good upholstery shop and have them do it. The cost might even be a wash, but a pro install should be better than a first timer's attempt. The shop owner created the bow seams from scratch, matching the previous one and had plenty of extra material to glue to the periphery to make it evenly tight. I found out later he also did the upholstery for Otis Chandler's Monterey cars, but most shops can handle this (alas, he retired). BTW, front/rear glass and rear side windows should come off to do this properly.
Sherwood
Old 12-24-2006, 12:07 PM
