North Coast Cab's Avatar
Identifying AN Fittings
How do you you measure AN fitttings? I'm trying to match up some fuel lines of various sizes and it doesn't say the size on the fitting anyplace. Is there a chart somewhere comparing the outside dimensions?
Thanks, John
1985.5 944 GTS
Old 12-23-2006, 05:17 PM
Slumlord
Porsche_monkey's Avatar
From memory 6AN is 3/8", 8AN is 1/2", etc...
http://www.plews-edelmann.com/brochure.cfm?brochure=3110&location_id=3848
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 12-23-2006, 06:49 PM
Zeke's Avatar
I think this is all explained somewhere on the Summit Racing site.
Old 12-23-2006, 07:21 PM
Early_S_Man's Avatar
Porsche Crest
John,
This Aeroquip catalog has some charts:
http://hydraulics.eaton.com/products/pdfs/fc/A-HOOV-MC001-E_06_Fittings_58-195.pdf
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 12-23-2006, 07:25 PM
Paul Thomas's Avatar
I'm sure you've found this info by now but 6AN = 6/16 or 3/8. Put the AN # over 16 to find the inch size.
Paul
My ignition is retarded.
Old 12-23-2006, 10:19 PM
Thanks for the help. So, if the hose ID is 3/8" that would make it an AN-8 fitting? The fitting ID's don't seem tomatch up exactly. I'm just trying to identify a bunch of fittings I have.
1985.5 944 GTS
Old 12-24-2006, 05:02 AM
DUK DUK is offline
DUK's Avatar
No a -8 is not 3/8", it is 1/2". See the note Paul wrote you. Put the dash number over 16. EX...-3 = 3/16", -4 = 1/4", -6 = 3/8", etc. BTW the AN stands for Army/Navy.
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 12-24-2006, 06:36 AM
billyboy's Avatar
AN, JIC, and SAE
AN is the same as JIC also. The taper on the mateing surface of the fitting is 37 degrees. Not to be confused with SAE fittings which are 45 degrees, although on fittings size -8 or smaller, they can interchange in a pinch. There are gauges availble to check the number of threads and the angle of the tapered seat. They are in little sets similar in design to feeler gauges.
'68 911 2.2 "E" PMO Carbs, Electromotive Crankfire Ignition, Adjustable Spring Plates, turbo tie rods, Bilsteins, headers, MB911 muffler...
"The sea merely lies in wait for the innocent but it stalks the unwary."
Old 12-24-2006, 07:20 AM
slammed1000's Avatar
Send a message via Yahoo to slammed1000
if you have never put any together you in for a treat trying to get the hose from fraying . make sure and tape the area you are going to cut and keep the tape on there as you push the fitting over the hose.
Old 12-24-2006, 07:31 AM
Apply rubber lube on the hose end also helps installing the hose into the fitting. A tetanus shot also helps since there's a tendency to penetrate finger skin with SS braid.
Sherwood
Old 12-24-2006, 12:18 PM
FOR THOSE OF YOU THAT DON,T WANT TO PUT OUT THE BIG BUCKS
FOR NEW GO TO musclemotor@mindspring.com , they have aeroquip used fittings and hose from NASCAR motors that have only been used once!! No kidding you can save a bunch of $$$$.
I,ve purchased an-16 for oil lines and an-6 for fuel line replacement on my 87 Carrera. Lots cheaper than the Porsche $500.00 replacement parts.
KEITH EPPERLY
87 SLANT NOSE TURBO LOOK CARRERA CABRIOLET
Old 12-24-2006, 07:54 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
The system is based on 1/16 's.
So 8= 1/2" etc.
Also...there are several angles in the system (sealing angles).
There are also some fittings that have sealing O-rings in them.
Make sure the O-rings match the fluid going thru.
Bob
Bob Hutson
Old 12-24-2006, 09:30 PM
