Replacing spacer Lug Nuts.
I'd like to replace my lug nuts that attach the spacer to my hub. I'm not sure who makes the spacer or the lug nuts. Can I pick these up at Home Depot or any auto parts store? They are M14x1.5 and the socket head is 22mm. They can't be too tall or else they won't allow the wheel to sit flush.
Thanks, http://forums.pelicanparts.com/uploa...1167182771.jpg http://forums.pelicanparts.com/uploa...1167182779.jpg http://forums.pelicanparts.com/uploa...1167182788.jpg |
No on HD. Check out your local nut/bolt supply house. Make sure you get Grade 8, minimum.
P.S. - That's not a spacer, it's an adapter. |
Thanks for that clarification Danny.
Anyone in the South Bay know of a good nuts/bolts house?
WOW! THat's right by my house. Thanks alot.
I think these will work http://www.fastenal.com/web/products/detail.ex?sku=40334
most spacers take a acorn style lug. take a picture of the spacer without a nut in it. if it is tappered where the nut sits it needs a acorn nut. if it is flat then you can use a regular nut.
Thanks, it's flat.
Paul,
Not to concern you if it's not necessary BUT I have similar spacers but mine are held on by steel acorn lugnuts. Are you sure they are flat sided? Why do you want to replace them anyway? EDIT: Let me ask that a different way. Is the area that the nut sits in dished? It looks as though it is in your pictures. If so, you need acorn nuts. |
Yeah, flat sided. I just checked them. Take a look at the nuts too, they are flat also.
Theyve built up crud on them and thought it would be good to replace them since there cheap and I have both spacer/adapters off. I guess i don't really have to. I certainly won't go searching all around town to find them. |
Cool.
Good insurance to replace them while removed. Be sure to torque them down correctly, 91 ft lbs. |
Yeah, I will. Here's a pic of the adapter. It's hard to tell but it is indeed flat.
http://forums.pelicanparts.com/uploa...1167192455.jpg |
Different type of adapter, but mine are flat too:
http://home.earthlink.net/~rolexwatc...scheWheel1.jpg |
And clean :)
I'd replace them while you have them off.
I'd use all metal lock nuts in that application instead of nylocks. -Chris |
looks tappered to me. put one of the lugnuts off the wheel in there and u will feel it center itself.
Paul-
Give a call to Parts Heaven. I bet they have exactly what you need. I think they are open this week. |
Yeah, they look tapered but there not. PH is closed for the holidays until Jan 2nd.
I'll say it again...Danny_Ocean...there are no "Grade 8" metric fasteners .... I think you mean property class 10.9 or even 12.9....
Wil |
It wouldn't surprise me if wheel lug nuts were grade/"property class" 8's. That would still be stronger than the aluminum alloy nuts that came standard. -Chris |
Here is a metric grade chart for nuts and screws/bolts......
http://www.fullermetric.com/technical/information/tech_grade_markings.htm Hope this helps with the discussion of "grades"..... Cheers |
For whatever it's worth, these nuts have a marking on the back. "J" on the top and the number "8" on the bottom.
Grade 8 SAE...I'm American. |
