saintz's Avatar
Carrera 3.2 no start
Hi all,
After being layed up for about 10 months due to my left to right conversion (that is another story) she wont start second time around.
I prepared everything and hit the key for the first time and she burst into life immediately,I ran her for about 20 mins then shut her down. I couldn't road test the car because it needs to be inspected by an engineer before it gets its road registration.
When the car sits for a while it will splutter once then you can crank and crank but it wont fire.
Anyway......I haven't been able to get the car to start again after dozens of attempts
Here is the checklist
new fuel. yes
strong battery. yes
new relay. yes (purchased because she had an idle problem before I layed her up for 10 months)
spark. yes
searched old posts. yes
fuel pump functioning. yes
checked plugs..... very fueled up, cleaned them, still no go.
any ideas?
Any help would be greatly appreciated I can't wait to drive her after all this time.
Old 12-28-2006, 03:12 AM
MBEngineering's Avatar
HI saintz go into the engine bay , and down the left side of the engine you will find 3 sockets, 2 black and 1 white, pull the white one off and bridge the connectors in the socket, the engine should start, once warm re-connect to the plug, I have a test plan for the 3.2 engine if you would like me to send it down PM me your Add, the info is the closest to the fault you have in the troubleshooting section it in the test plan/book. Happy new year .
regards mike.
Old 12-28-2006, 03:48 AM
sounds like fuel filter to me...
So it starts if you leave it for a while yer? (i.e all the crap can settle)
_____________________
'73 RSR Interpretation
Old 12-28-2006, 06:05 AM
Porsche-pa
75Carrera's Avatar
TDC Sensor? That will sure prevent it from firing up...
Current Garage:'04 996TT S Cabriolet, 1975 911 Carrera 3.2 powered (my Precious),
Also rans...
'02 996TT, '03 996TT, 1967 912, 95 993 C2 Cabriolet, 76 911S Carrera, 2014 Carrera S, 2014 Turbo S, 1999 AMG SL, 1966 Lotus 7,
Donny
Old 12-28-2006, 06:58 AM
saintz's Avatar
Thanks guys, I'll check it out and let you know.
Newcastle NSW Australia.
1989 ROW Carrera 3.2 Slate Grey.
Old 12-28-2006, 10:43 AM
saintz's Avatar
Mike
I bridged the conector but no difference.
the white fitting that it plugs into only had one pin on it.
Old 12-30-2006, 03:29 AM
Saintz,
Hop on to Rennlist and in the Technical Forum is a great article on No Start diagnosis for Carrera's.
Ned NYNA 11
87 Carrera targa
98 BMW 528i
98 Volvo V70
Old 12-30-2006, 03:45 AM
HI saintz did you bridge the socket you pulled off or the one on the engine , as the socket you pulled off is the one you should bridge , should have 2 connecters in it as in the photo below.
pull off the top white socket.
the jump wire has to go in the end of the socket.
like this to now tell the DME the engine is in a default setting and will not overfuel .
PM me your snaill mail ADD and I will send you the test plan.
regards mike
Old 12-30-2006, 04:43 AM
F16driver's Avatar
Mike,
I have a question about your bridging technique. In the picture you posted, you have the yellow wire connecting the 2 small holes in the center of the plug. Would you get the same result if you connected the 2 larger slots on the plug, where the connectors fit in the plug from the engine side?. (spade connection openings)
I'm just curious if this gives the same result?
Thanks,
John
Old 12-30-2006, 09:05 AM
HI John yes that is OK ,I only photo'd the yel' wire as a guide to show it was that plug and not the engine plug.
regards mike
Old 12-30-2006, 09:31 AM
How did you test the spark?
Old 12-30-2006, 10:50 AM
saintz's Avatar
Removed a plug, put it back in it's socket, held it with insulated material and observed the blue white spark as we cranked the motor.
Old 01-01-2007, 02:19 PM
