under dash wiring question
Does anyone know what goes on term 56 with black/white wire on light switch? Also, is this yellow wire connection correct? It goes to the hi-lo beam stalk on the steering column. Does yellow female spade go to term 56? If so, where does yellow male space connector go? Oh, its for a 77 Targa.
Old 12-27-2006, 05:40 PM
Say again???
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 12-27-2006, 06:30 PM
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-27-2006, 10:16 PM
Ove Ove is offline
911 driver
Ove's Avatar
Bob,
Take a look here:
Bosch Terminal Designations
From the list:
56 Headlamp
56a High beam, high-beam indicator lamp
56b Low beam
56d Headlamp-flasher contact
Yellow is the color of the low beam output on the hi/lo beam switch on the steering column.
Ove
'77 911S targa
Old 12-28-2006, 12:14 AM
Bob,
I just replaced my turn signal/high beam switch and had the same question regarding the yellow wire. My old wire bundle (88 Coupe) came out and had the yellow wire exiting the harness and connected, what seemed like, to itself and going back into the harness. That's the way I installed the new switch and haven't found anything that doesn't work yet.
88 911 Coupe
09 Jetta Diesel
10 Honda Accord
88 450SL
95 Sabre 362
Old 12-28-2006, 02:59 AM
the yellow wire is the auto-eject seat, be careful not to cross it
bob
66 911... no more
90 mazda miata
76 unimog 406
Dune Buggy!
Old 12-28-2006, 07:57 AM
Very funny unimog, you have been watching too many james bond movies......
Old 12-28-2006, 01:33 PM
Hey Bob
E4 "dimmer beam" is hi or low beam headlights.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-28-2006, 02:20 PM
