Reading this as I'm about to do this.
I noticed that the original badge is flat. The replacement I bought is convex from the front. Are they all like that? Yep the gasket is too small. |
I bought mine here and it was not fun to install. too small.
Silver 1980SC Euro coupe |
OK, this is what I did. Dropped the gasket in a coffee cup of hot water. Installed the warm gasket on the badge with the gasket lip in the right place on the top of the badge. Then installed both on the hood. Started to tighten down the badge..........Then, I slipped a small strip of sandpaper under the gasket with the spaper grit touching the rubber gasket and the smooth paper on the hood. As I tightened it down, I slowly pulled the gasket into place. It worked perfectly. Almost need three hands to do it right so get a fellow detail person to assist.
Steve |
Steve,
Mine were so far off your sand paper method would have not worked. I still think there must be more than one manufacture of these gaskets to account for the various differences in the ease of installs. Are any of the current gaskets OEM? It's no trick to have these gaskets made, but the costs probably out weigh the return...
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
Just a thought while reading this thread. Is it possible, or likely, that some of the gaskets are old stock and have shrunk and become a bit hardened? That could account for gaskets that fit and don't fit coming from the same supplier. I'm imagining a bin of individually wrapped gaskets sitting on a shelf in a warehouse and the bin gets refilled periodically with new stock when the supply gets low--and who knows how old the "new stock" is from the manufacturer/wholesaler/distributor.
Just a thought.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
just go to the porsche dealer locally, the gaskets are like 5-7$ NEW, and u can try them on the spot with your badge for a fitting.
also, use BOILING water for a few seconds, not just warm tap water.
1989 944 2.7L n/a |
I believe it boils down to one thing, and one thing only. Either you have an original OEM part or an aftermarket reproduction part. The OEM part fits without any boiling water, stretching, gluing, etc., period...
Here's the P/N - 7L5-853-611-B - List price $5.40...
A bit off topic fellas but has anyone got a source for a SILVER hood badge. I've read quite a bit about their existence and Porsche's objections but someone must have some sitting around.
Nod ...Nod, wink..wink? Thanks, Scott P.S. Great to see you in this thread Mitch I'll catch up with a PM.
Scott "Houston, Tranquility Base here, the Eagle has landed" Silver 1984 M491 Sunroof Coupe |
