Banned
fabiraning944's Avatar
911 sc non spark what look for?
Alina post deleted -Z-man.
Old 12-30-2006, 02:25 PM
Blanco's Avatar
The CDI box could be faulty as well as the coil itself. If all that is cool, check your green wire from the distributor. If it is brown and cracked, its possible that your CDI is not getting a trigger signal.
It could also be a grounding issue. Check you transmission strap as well as clean all your grounds.
I'd check your grounds first.
1982 Porsche 911SC Coupe - Factory Short Shift |7:31 R&P in AL case | Toyo RA1 Tires | Corbeau TRS seats | M&K 2 in 2 out muffler
Old 12-30-2006, 05:18 PM
