david n jones jr
Guest
Posts: n/a
Alternator light flashing?
I am working on a 71 911T that has an alternator light that blinks the whole time the car is on. Owners manuel says "flickering alternator light can mean loose fan belt (it s not) or bad voltage regulator". Does this year have an external voltage regulator? Any other trouble shooting ideas?
DaveJ 71 911t
Old 10-23-2000, 10:37 AM
Early_S_Man
Guest
Posts: n/a
Yes, it has an external regulator over on the relay/fuse/CDI-unit 'console' on the left side of the engine compartment ... bolted to the fender inner panel.
A flickering alternator light can be caused by loose ground straps, from body to transaxle, for example ... and also by bad brushes inside the alternator.
Warren Hall
1973 911S Targa
Old 10-23-2000, 11:04 AM
