CV Joints
I took my tranny out the other day to rebuild it and when I was removing one of the CV joints/axles one of the Ends just Slid right out.. Is this Normal?! What usually holds it together?
71 Targa 2.4 WEBERS 915 box Drivetrain - http://forums.pelicanparts.com/porsche-911-technical-forum/410787-drivetrain-project-complete-3yrs-pics.html Interior - http://forums.pelicanparts.com/porsche-911-technical-forum/452686-interior-refurb-carbon-fiber-71-a.html#post4433500 |
Kantry Member
I'm guessing the axle slid out of the CV joint. I have no experience with newer units, but on the old E, the axle is held in place in the CV joint with a circular clip. Check the end of the axle, there should be a groove just in from the end. That is where the clip seats when the joint is in place.
Les
Best Les My train of thought has been replaced by a bumper car. |
It is an older CV Axle from a 71 T . I'll have to check to see, must be missing the C clip that would normally hold it in place.
71 Targa 2.4 WEBERS 915 box Drivetrain - http://forums.pelicanparts.com/showthread.php?t=410787 Interior - http://forums.pelicanparts.com/showthread.php?p=4433500#post4433500 |
CV Joint Snap Ring, 911 (1974-75) Brand: Genuine Porsche [Photo] 999-041-012-01-OEM $1.50
This part fits all '69 thru '75 four-bolt axles with M10 bolts. If you are interested in specs ... http://www.metricmcc.com/catalog/Ch2/2-214.pdf
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
