Send a message via AIM to fierochris Send a message via Yahoo to fierochris
Clutch cable came off. (pics)
Alright, I did a search and i couldnt find anything on this issue.
I lost my clutch, and after inspecting i found this.
the cable came out of the retaining tab completly, im trying to get it it between the nuta again, but i just cant muscle the cable back that far. is there a way to get the tention off the cable so i can move it back?
71' 911T Targa, current toy.
86.5 928s traded for new 911
71 911 Targa w/ gas burners, PMO's, *sold*
Lamborghini diablo replica w/ 350 V8
85.5' 944 n/a euro ( gave to dad )
87 fiero cp. candy blue, chrome 16's
90' DSM 24psi. 18G fmic,
82' benz 300sd turbo, intercooled.
73' Karmann Ghia cab. sold
04' Standard 250s ox, euro bb 28/10 gearing, odyssey, profile, 29lbs,
check out www.vintagevwcars.com
wanted: 914, 944, 928 project
Old 01-07-2007, 12:04 PM
Somatic Negative Optimist
Gunter's Avatar
Man, what a grease pit.
Yes, there is a procedure for adjusting the clutch (Including the cable)
The C-spring tension needs to be released before you can move the cable-ends and the cable needs to sit in the tube inside the tunnel.
I suggest that you first have a serious clean-up with steam perhaps?
Get a Bentley Repair Manual for your 911.
There is a Tech article on PP.
You can do a search here but you'll love the Bentley.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 01-07-2007, 01:01 PM
i got the cable loose. i just took it off where the cable end holds on the transmission case . i now have the cable housing set in place between the adjusting nuts. but i cant get the inner cables end knarp hooked again. i have the cable loose. but i need about another inch of travel. any idea how i can get this?
Old 01-07-2007, 01:44 PM
ok heres how things look now.
figure 1 shows the housing in its proper placement and the adjusting nuts with the retaining tab between them.
figure two shows the cable itsself. i need to obtain about a inch more slack in the cable so i can get the knarp behind the flange on the trasmission.
can anyone tell me how i can get more slack? the nuts are backed out all the way on the ajustment.
Old 01-07-2007, 01:57 PM
figure 1
figure 2
Old 01-07-2007, 01:58 PM
i still need more slack. does anyone have the answer? I really want to get my can back on the road.
Old 01-08-2007, 05:03 AM
T77911S's Avatar
have someone lift up on the clutch pedal. most likely it is on the floor.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 01-08-2007, 05:18 AM
i noticed that made it easier to pull the cable. Its wedged all the way up now. there must be a way to get more slack in the cable i dont need much more then a inch or maybe two at the most.
Old 01-08-2007, 05:27 AM
Not Quite Banned
Thomas Owen's Avatar
Your Figure # 1 shows the cable coming down at what appears to be a rather sharp angle from the left. Are you sure you have the housing and cable routed properly?
good luck -
Thomas Owen
1972 911T
1972 911S
Old 01-08-2007, 05:47 AM
Gunter's Avatar
Something looks weird. What year is this 911?
Post a clear pix of the levers etc. so I can see the rest of the clutch adjustment.
Like this:
Old 01-08-2007, 08:32 AM
Like this:
my transmission doesnt look anything like that. This is a 71' T i beleave its a 901 trans?
Old 01-08-2007, 08:34 AM
Ok is there anyone here that can help set me straight? i cant even find a picture of a tranny like mine. its deffenitly not even close to what gunther posted. I still dont have the slack in my clutch cable. i have the rear hooked up now. but now i cant get the cable close enough to the clevis on the clutch pedal to get a thread started. someone? Anyone?
Old 01-08-2007, 01:04 PM
Did you resolve the original problem which made the cable come apart?
The clutch you have is only found on a 70 or 71. You should have no problem putting on the cable end if
1: You disengage the plastic guide ( I don't know what the correct name is) from the release fork.
2: The stopnuts are positioned full loose, as you have shown.
3: The clutch pedal is wedged up.
4: You put the cable end into the attachment hole and slip on the retainer.
5: Last is push the plastic guide as far as possible onto the threaded cable sheath/stop nuts. Then engage the plastic guide onto the clutch release fork.
PS I would consider upgrading this plastic guide to the metal one as the plastic will eventually break off the 2 tabs and strand you.
Good luck
Ed
'69 911E 2.7MFI ;996TT;987.2 CaymanS
'71 Volvo P1800E wife's; AMG SLK wife's
'71 Volvo race car
944S; 986S ; 734WHP drift car (son's)
Old 01-09-2007, 05:13 AM
Gunter's Avatar
fierochris:
It would have been a lot easier if you would have stated the year/type from the beginning.
Your signature doesn't help either:
86.5 928s *new baby*
I repeat, take a picture of your clutch levers (like my example) so we can see more.
The cable is first attached to the front, then the rear in a certain fashion.
The cable you have in the picture is missing the boot and looks kinked.
If the cable is old, get a new one.
If you want us to help, how us pictures as requested.
Old 01-09-2007, 07:52 AM
