-   -   Factory Alarm system (http://forums.pelicanparts.com/porsche-911-technical-forum/323157-factory-alarm-system.html)
Ken911 01-04-2007 06:09 PM
just hooked it up finishing the car up the thing is when It is set I use the key to unlock the door, as soon as the door is open the alarm goes off, no time to get the alarm key in the door to turn it off before it goes off is it supposed to do that?
dlagerstrom 01-04-2007 06:12 PM
Does it have the key in the door?
If so, I think you are supposed to open the door just enough to get the key in and disarm the alarm.
Or is it different in an 85?
Ken911 01-04-2007 06:38 PM
Yes it's the one with the key in the door, it's in the 88, i'll try cracking the door see if that works. tomorrow in the daylight so I dont wake up the neighbors LOL
madmmac 01-04-2007 07:19 PM
Yes, just crack the door far enough to disable the alarm.
tedder 01-05-2007 09:52 AM
on my 86 it will go off if there is more than about 1.5" (3cm) between the inside of the door and the back of the door jamb. You really can't open it more than the minimu required to get the key in...
Ken911 01-05-2007 06:03 PM
tried that and it works thanks
dorschman 01-05-2007 06:45 PM
if you have the original manual for the car it is explained in there as well.
