elpello's Avatar
Porsche Crest High Idle 3.2 Carrera
When my car gets to operating temp it idles at about 1100-1200 RPM. Is this normal. Owners manual said it should be around 800.
This is an '87 Carrera
Old 01-07-2007, 04:01 PM
I had a flucuating idle and based on someone's suggestion I changed my O2 sensor. You can also try cleaning out the idle stabilization valve since that's a cheap and easy thing to try.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 01-08-2007, 06:52 AM
MBruns for President
JeremyD's Avatar
What Buck said - and clean your ICV and check your throttle cable adjustment to make sure it's enaging the "idle microswitch"
Old 01-08-2007, 07:04 AM
