Czar of C.R.A.P.
dfink's Avatar
reference sensor order please please
reference sensor question. I know I've read 25 posts but I can't find one that says which order in the bracket the sensors are. Everyone says put them back how you took them off. Well would have been a good plan.
I know the cylinder head is top which is middle and bottom in the bracket.
66 912 Coupe
84 Carrera Cab Hardtop HC3.4 Hyper Carrera
2005 Dodge Magnum 5.7 HEMI
Cabriolet Racing And Performance C.R.A.P. Gruppe #1
Put on some C.R.A.P. and drive....
Old 01-14-2007, 09:17 AM
Somewhere in the Midwest
MotoSook's Avatar
The two reference sensors are identical, so it really does not matter where on the bracket (in the engine bay) you put them. If you didn't mate the speed sensor connector and the TDC sensor connect to their mating connectors on the wire harness end, the car won't start. Then you just swap them.
Old 01-14-2007, 09:31 AM
Czar of C.R.A.P.
dfink's Avatar
I understand they are the same. I also understand swap them. But where are they suppose to be. This is after a rebuild and 50 things could keep it from starting I want to have all the known issues correct.
66 912 Coupe
Old 01-14-2007, 09:33 AM
MotoSook's Avatar
Do don't understand the hangup. Does it matter if the TDC sensor or speed sensor is in the third slot or second slot in the engine bay bracket?
Old 01-14-2007, 09:39 AM
Czar of C.R.A.P.
dfink's Avatar
It is running so I must have guessed OK. I marked the wires top middle bottem. I wouldn't matter where they wind up either could be in either spot as long the correct wire is connected. Problem is I didn't mark the harness as reference or TDC I just had top middle bottom. Since I had every thing off the car I just didn't know which was which. I just wanted to have it correct so the car would start. But it wouldn't matter in the end. Thanks for the reply.
66 912 Coupe
Old 01-14-2007, 11:45 AM
