Never, Ever Do This
65_lincoln's Avatar
Thanks to this board for lug nut help!
Just wanted to say a huge thanks to this board, and especially John Walker, for the information I needed to remove four broken AL lug nuts which had sheared off at the bottom of the hex section. This was my first real project on my first P-car, so I'm pretty fired up. Now all lug nuts have had anti-seize applied and have been properly torqued.
The nuts were seized to the studs, and despite my best attempts to soak them down with PB Blaster (I was afraid to use a torch and heat, for fear of damaging the finish on the wheels), I broke off a couple.
It took me a couple of hours because I was very slow and careful, but I was able to remove the ball sections of the nuts using the deep 3/4" hole saw and a sharp drift, without damaging my Fuchs at all.
Now for my next project! I did bugger up one of the studs a bit with the edge of the hole saw, so I want to replace that. I've got a steel lug nut on it for now, but didn't want to foul up the threads of a nice AL nut with bad stud threads.
Thanks to all of the great guys and girls here who collectively have so much knowledge and experience!
John
1987 Carrera Targa, Lagoon Green
2012 Audi S4, Monsoon Grey
1965 Lincoln Continental convertible, Maroon--gone but not forgotten
Old 01-08-2007, 09:09 AM
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
If you want you can try using a "Die" to re-form the threads on the stud if the threads are to terribly damaged.
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 01-08-2007, 10:02 AM
Light,Nimble,Uncivilized
Depending on how back you damaged the threads just running a steel lug nut all the way through the damaged area may be enough to clean up the threads.
Drago
'69 Coupe
R #464
Old 01-08-2007, 11:14 AM
Never, Ever Do This
65_lincoln's Avatar
Thanks Drago, my old friend. I know that trick from my days in the bicycle shop, so I ran a steel lug nut down each stud with a little cutting fluid to try to clean them up. Unfortunately, there was some material loss on one stud thanks to the hole saw, so I'm planning to just replace all four studs.
I guess I need to pull one out to check for length (it's an '87 with 7" Fuchs on the front, so I'm assuming the stud length should be 45mm based on what I've read??). I need to take a look at how to get at them, but I'm hoping that on the front it should be pretty easy. But that may be a question for another thread.
Thanks again Drago and MattAlpha.
John
Old 01-08-2007, 11:43 AM
