Source for sheet Lexan?
Anybody know a good source for coated (scratch-resistant) Lexan sheets, or maybe has some in the shop they'd sell me? I need just enough to do the rear quarter windows, which are coming out anyway to re-do the headliner, so I figured I might as well Lexan 'em. I already have the curved Lexan for the windshield and rear window, but stock 3/16" Lexan will be just fine for the flat quarter windows.
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
drag racing the short bus
Maybe ask Chris Streit. I believe he sells Lexan pieces, though I don't know about whole sheets.
The Terror of Tiny Town |
Only asked about "sheets" because that's the way it usually comes--typically two-by-four-foot pieces.
Diss Member
Home Depot sells the stuff but I'm not sure how it is coated. If you are making windows you will want a good hard scratch resistant coating on it.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Yes, that's what I have on the windshield and rear window. they demonstrate it by actually sanding it, and it won't scratch.
try a plastics company
We have a local plastics company (Midland Plastics) that sells all kinds of plastics.
I know they have 4 by 8 sheets of Lexan, I'm sure they even have the scratch resistant type. I bet if you look locally, you will find a buisness that sells it? You would be amazed that the stuff they have! Good luck Jeff |
Lexan is a brand of polycarbonate sheet. I think you want abrasion resistant polycarbonate sheet. Mcmaster Carr has it.
'82 911SC racecar '05 WRX STi |
Information Junky
Unless they're 'sanding it' with wet news paper, I don't buy it. please prove me wrong, but I believe that crystaline aluminum oxide (syth-sapphire) would be the only (clear) material to stand a chance against common sand paper. . . and you wouldn't find that on a thin pice of lexan.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Lexan sheet source
Try Hoerr Racing Products. www.hrpworld.com
island 911, go to Speedglass Racing Windshields. Steve Weiner believes it, and so do I.
Stephan - please post whatever you find. If there's true scratch-resistant Lexan out there, I'd like to see it. Not knowing of a scratch resistant brand is the only reason I haven't put Lexan in my car yet.
As well, I'm going to check the links the other posters provided.
dd74 - check McMaster-Carr, type in "polycarbonate" into their search field, click on "plastics" on the right, then look down the list.
They also have "bullet resistant polycarbonate"
Information Junky
A very good friend of mine works for Honda R&D and was telling me about some lightweight window options. From the descrptions I think that the speedglass people are selling the same. . . essentially laminated glass with a very tick PC core, clad by relatively thin glass. I could be wrong, but considering I design plastic lenses and such for consumer and medical products and often have the GE plastic rep in the office, discussing available plastics, I'm thinking I'm fairly current on plastic hard coats. --and we're not likely to find a 'sandpaper resistant' plastic sheet at HomeDepot. Glass can certainly "resist steelwool" (as they claim) . .. but even glass is not going to survive sandpaper.
...well, given anyone would actually sandpaper their windshield...for whatever reason.
Air Medal or two
Laird plastics in Seattle...1/2 or whole sheet
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
island 911 is right. They demonstrate that Lexan by "sanding" it with steel wool, not, as I wrongly implied, sandpaper.
We use some Lexan for sign faces in my shop, and believe me, it will scratch. Try a screwdriver or utility knife on it. But to answer your original question Stephen, try any local plastics company, or sign supply wholesaler, or even try a local sign shop - they should be able to get it, might even have some scrap around. If you can't get it anywhere locally let me know and I'll get some to you.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar. '11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX. |
By the way, island911, if you're interested I'll be happy to mail you a piece of the Lexan I'm using--a scrap from what I trimmed off the windshield--so you can maybe figure out what it is. If you wish, PM me your address.
Information Junky
Seeing that they sell over-sized windshields, I was curious as to how you got it to cut down. I imagine that it cuts fairly easily. (?) --that would exclude the surfaces from being glass. --hmmm.
Yeah, I just cut it with a 20-tpi Plexiglas blade in a saber saw and was able to sand it relatively easily with a belt sander, to true the small deviations in my initial cut. You'll see from my PM to you that I don't think it has any glass in it either.
