Silverstar headlight bulbs
I replaced the bulbs in my headlights last night, trying to get more light on the road without spending mega bucks.
I bought the Silverstar by Sylvania at wal-mart, figured I could take them back if the were not as I expected, especially since they were almost $40. Anyway, I drove to work this morning at 5am and was pleasantly surprised at the difference the new bulbs made. The light is whiter, not the blue color, and really made a big difference in being able to see the road. Just a little info that may be of some help to others like myself who don't see as well as they used to, and dont want to do the H4 upgrade.
KC 88 Guards Red Targa (sadly sold )2005 Boxster S 1st Porsche 73 914 (long gone) |
Thanx for the info KC. I was looking at these the other day and wondered if they worked. BTW How are you doing? Haven't talked to you in a while.
75 911 Indian Red- RUFWAN2B 2000 Boxster 2000 & 2007 Dobies www.stahlwerks.com Cages and preparation for your Porsche “People who never make mistakes must get tired of doing nothing” Bill : The origin of the orgy of Porsche |
KC,
I put silverstars in H4s over the Christmas holidays and was also pleasantly surprised. I agree, not 'blue' at all. I was able to clean the headlight buckets at the same time. Much more focused light! Heck, I was happy to get the headlight buckets out finally! My next small project will be to install relays for the headlights. I cleaned and replaced the bulbs in the taillights too. Very satisfying! Later, Mike
Mike '84 Grand Prix White RoW Carrera |
I thought 88's had H4's? These are very good bulbs and are a big improvement. I have them in my BMW.
88's came with H5s in the US. I'm not sure what the RoWs came with that year.
You fellas have a part number for the Silverstars? I have H4's and would like to upgrade.
Thanks,
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
I think the number on the bulbs was 9004, if you have H4's I;m not sure if it would be the same.
Hey Duke, how's your Hot Rod project comming?
KC -- Are the bulbs direct (drop-in) replacements for the stock bulbs, or did you have to modify anything?
Thanks!
1984 Targa |
rhymes with targa
Sylvania has a few different 9004 models though. I'm using the Silverstar 9004 STs. These throw white light, but there is a model above this (XT?), but I noticed the bulb had a very slight blueish tint to it. I wanted to stay away from the wanna be HID l00k.
I cleaned the inside of my H5s using rubbing alcohol and installed new desiccant packs. Happy with the results. No modifications needed for these bulbs. I also installed the Sucro Relay. |
The bulbs are direct replacement, witn no mods. And the bulb does have a slight blue tint to it but the light it gives off is white.
So H5's are not as good as H4's? Since 5 is higher than 4, I would have thought that the newer H5's were better. Learn something new everyday.
I could not find the H4's in Silverstars at Wally World, though they had some bulbs with "real zenon gas" made by Pilot. I did not buy those, so don't know if they are any good. |
I installed the SilverStars in mine last year... Amazing difference!!! No wiring mods needed, straight plug and play set-up.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
My H4s were direct replacement too. I bought mine at Advanced Auto. The bulbs do have a blue tint but give a very white light. I understand that any tint is 'reducing' light output, which isn't good, but the lighting is much better, IMO.
I think the lighting will be better once I install relays too. To do list... Later, Mike
Are the Silverstar's stock wattage for the H5's or higher??
$35 and a six pack to my name..... '88 Diamond Blue Carrera CE 3.4-SOLD
Did a quick search on these. Take a look at this thread from Miata.net. The life of the bulbs sounds short.
http://www.miata.net/products/lights/sylvania.html
'08 RX350 (Hers) '84 911 Carrera '83 911SC Cabrio '06 Miata |
Bill is Dead.
The number 9004, 9005, 9006, (etc) are not bulb part numbers from any specific manufacturer, but are rather they designate the type of bulb. I knew that much from working at a parts store years ago, but I tried to find a good chart that shows them all. This is what I found, but it is a little lacking. H3: 55w H4: 60/55w H7: 55w 9003: 65/55w (dual element, hi/lo) 9004: 65/45w (dual element, hi/lo) 9005: 60w (single element, hi) 9006: 51w (single element, lo) 9007: 65/55w (dual element, hi/lo) Wattages shown are the designed wattages. I guess we can consider them "minimums" now since most aftermarket bulbs produce more light intensity than the original designations. Something IMPORTANT to consider: Sometimes, the increased light intensity is a function of better technology. But sometimes the increased light intensity is a function of having installed a higher wattage bulb. Since WATT=AMPxVOLT, and since VOLT is a (mostly) constant value in our cars, then higher WATTS means you are pulling MORE AMPS. Install a relay so that you don't melt your wires or set your car afire.
-.-. .- ... .... ..-. .-.. -.-- . .-. The souls of the righteous are in the hand of God, and no torment will ever touch them. Last edited by cashflyer; 01-11-2007 at 03:07 PM.. |
Just for the record, the Silverstars I installed (H4s) were stock wattage - 60/55, or at least that what they are claimed to be. I still think we all need to install relays, personally though.
Mike
Headlight utopia?
also another good one. 911 Headlight 101
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
