SC Shifter Knob Removal
Ok, anyone knows how the SC top shifter knob comes off? It doesn't appear to screw off and can't see any set screws?
Thanks, Dan |
Pull it off. It is held on by friction. There is a crush sleeve between the knob and the shifter shaft. It can be quite hard to remove one. I usually do it with the shifter out of the car in a bench vise and I use a slotted block of wood, or the equivalent, and a hammer.
JR
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle |
Thanks JR, seems like a part that easily damaged or cracked. The wood seems like a great idea.
Thanks again, Dan |
Somatic Negative Optimist
Spray some penetrating oil on the crush-sleeve from underneath.
Then use an adjustable wrench on the stick under the knob and tap with a hammer under the wrench. Some come off easier than others.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Thanks Gunter, mine seems pretty stubborn!!
I'll also try the penetrating oil.Dan |
It's a beotch. I tried everything, the wrench underneath, piece of wood, etc, and after it began to chip I gave up and finally had to cut it off with a dremal. This of course destroyed it, but looking at the pieces it's just an ABS plastic POS anyway.
Price a new one....quite a pricey POS.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
Sultan of Sawzall
I always wondered about how to get access to the bottom of the knob on a mid-80's 915 with the shift boot that butts up against the bottom of the knob. What's the trick to one of them? How do you get the leather boot low enough on the shaft to get something underneath the knob to coax it upward?
Gruppe B #319 2 '86 911 Carrera coupes (red & white) '66 Corsa convertible 140/4(red) '66 Monza coupe 110/PG(white) '95 993 cabriolet (wife's) |
