-   -   Can someone explain this engine bay pic to me? (http://forums.pelicanparts.com/porsche-911-technical-forum/324797-can-someone-explain-engine-bay-pic-me.html)
Gogar 01-14-2007 09:25 AM
What is the belt-driven accessory on the left? The car is supposedly an 80 SC, A/C delete. Also, what's the silver box up on the top that looks as if it's mounted to the engine lid?
Thanks and I look forward to the education.
http://forums.pelicanparts.com/uploa...1168795511.jpg
Kirk911SC 01-14-2007 09:27 AM
Air pump, and rear window wiper motor cover.
Zeke 01-14-2007 09:38 AM
Definately air injection pump for smog. I believe these started in '75 and I don't know when they were replaced with a better system. Perhaps not until the 3.2 in '84. Anyway, cars w/o cats had these.
Gogar 01-14-2007 09:43 AM
Ok. I was gonna ask if it was smog pump, but I only thought that was through the mid-year cars.
So can I expect that this car has been run relatively hot for it's whole 80K lifespan?
Eric-325I 01-14-2007 09:53 AM
The PO of my '79SC removed the smog pump and harware and gave it to me in a box. He claimed the car ran better after removal... As far as I'm concerned, he saved me the trouble.
I don't believe the smog pump would increase engine temps appreciably... You may be thinking of the thermal reactors used on some of the mid-70's cars before the use of a cat.
Eric
holtjv 01-14-2007 09:54 AM
yes, remove the air pump, as I did--gained a bit of power but I also replaced the cat with a bypass at the same time so I can't claim that for sure. if nothing else, it's one less belt to break off and cause havoc in a running engine.
Jack
Gogar 01-14-2007 09:59 AM
Yes I was confusing smog pump with thermal reactors. I guess I always considered it as parts of te same zany system.
Thanks!
MBAtarga 01-14-2007 03:27 PM
Milt, the smog pump disappeared on the '80 model.
Scott R 01-14-2007 05:04 PM
My 80' never had one, the heads don't even have a place for the air lines.
pwd72s 01-14-2007 06:40 PM
Yo, Milt...check off topic...I left a message for you there...
