Band.
Can someone explain this engine bay pic to me?
What is the belt-driven accessory on the left? The car is supposedly an 80 SC, A/C delete. Also, what's the silver box up on the top that looks as if it's mounted to the engine lid?
Thanks and I look forward to the education.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
Air pump, and rear window wiper motor cover.
- '00 Dodge Viper GTS - Steel Grey - Yep...a domestic. - '87 930 - Guards Red - Sold - '82 911SC - Grand Prix White - Gone - '78 928 - Silver - Long gone - '04 Subaru WRX wagon - Sold |
Definately air injection pump for smog. I believe these started in '75 and I don't know when they were replaced with a better system. Perhaps not until the 3.2 in '84. Anyway, cars w/o cats had these.
Band.
Ok. I was gonna ask if it was smog pump, but I only thought that was through the mid-year cars.
So can I expect that this car has been run relatively hot for it's whole 80K lifespan?
The PO of my '79SC removed the smog pump and harware and gave it to me in a box. He claimed the car ran better after removal... As far as I'm concerned, he saved me the trouble.
I don't believe the smog pump would increase engine temps appreciably... You may be thinking of the thermal reactors used on some of the mid-70's cars before the use of a cat. Eric
'79 SC Silver over Black... Sold |
yes, remove the air pump, as I did--gained a bit of power but I also replaced the cat with a bypass at the same time so I can't claim that for sure. if nothing else, it's one less belt to break off and cause havoc in a running engine.
Jack
Warren Hall (Early S Man), 1950 - 2008 ------------------------------------ 2006 Tri D675 Scorched Yellow 2006 Ducati Sport Classic mono SOLD 1979 SCWDP #0020 Talbot Yellow SOLD |
Band.
Yes I was confusing smog pump with thermal reactors. I guess I always considered it as parts of te same zany system.
Thanks!
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Yo, Milt...check off topic...I left a message for you there...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
