Hi all,
Would the lower valve covers from a 964 motor bolt right up to a 3.2 Carrera motor, which has been twin plugged? I assume the CAM towers are the same height between the two motors? Also, I need a left side lower valve cover, if anyone has one to sell?
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Irrationally exuberant
They are not a straight bolt on, though I have tried and may try again.
The cam tower castings are the same but the studs for the valve covers are 6mm on the 964 vs 8mm for the earlier cars. I tried drilling out some 964 valve covers and that was not successful (they leaked IIR). I was thinking of replacing the cam carrier's 8mm studs with 6mm ones but I probably won't now. I was working on a friends '88 or '89 Carrera cab a few years back and I noticed that the casting number on the cam towers was a 964 #. That's what made me think about trying 964 lower valve covers on my twin plug motor. -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Thanks Chris. SOmeone told me there were a direct bolt on, but now I'm not so sure
Chris is right. The cam towers are the same except for the stud diameter. Either change the studs or drill out the holes. I have spare 964 covers and have been contemplating drilling them out for a trial.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Wyd,
Pm me and I'll tell you about what I did. Bill |
Hilbilly Deluxe
Merv, it is not necessary to get 964 valve covers. Any machine shop that is capable of drilling the second spark plug hole in a 911 head should be able to mill the plug holes in your standard lower valve covers, and fabricate clips to hold the lower plug wires in place.
Dont forget the chain box on the right side of the engine, there is a spot that needs to be relieved to make room for the #4 lower plug. Depending on the type of plugs you plan on using, you may also need to replace one of the lower head stud barrel nuts on each cylinder with a hex head nut from an air-cooled VW Bug. Tom |
