87 Carrera 40k inner CV boot clamp
Newbie alert. Did a search on missing CV inner boot clamp. Question: If the clamp is missing should the boot be removed and repacked? Is a tie wrap a permanent fix?
87 Carrera Cab GP White
01 740i Sport
03 Honda Odyssey
Old 12-24-2006, 03:29 PM
Large tie wrap is fine, about the same width as the recess
Keith Epperly
87 slant nose turbo look carrera cabriolet
Old 12-24-2006, 08:27 PM
Tried a tie wrap and it appears as though the boot is still slipping over the bump on the axle and leaving grease. Perhaps I cannot get the tie wrap tight enough. I guess I should try a clamp. Can anyone recommend what size/type of clamp I should order from pelican?
01 740i Sport
03 Honda Odyssey
Old 01-15-2007, 11:15 AM
