Throw it on the ground!
Momo 350mm wheel vs stock
Changed my wheel today and thought I'd post a pic of a momo 350mm vs the stock wheel. Visually not much of a "size" difference, however, the feel of the wheel, ease of turning and ease of getting in the car are markedly improved. I should not have waited so long.....could be the best mod to date! I also added a 1" alum spacer which has reduced my reach and increased comfort (I'm 6'1"). Pics are a little dark, but you should get the idea.
First pic: momo on top of the stock wheel
Stock
1" Aluminium Spacer
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 01-11-2007, 07:28 PM
Looks great - a definate visual improvement on stock in my opinion.
Charles
'84 911 3.2
Old 01-12-2007, 09:59 AM
RETIRED
Joe Bob's Avatar
Blocks line of sight on the gauges but is def improvement....
2012 ML350 3.0 Turbo Diesel
Old 01-12-2007, 10:01 AM
What was Porshe thinking with the 4 spoke wheel?
The 3 spoke is bad enough, I still have the 3 spoke. I need to make the change.
Looks great.
pat
18,000mi a year 84targa
Old 01-12-2007, 10:07 AM
Never, Ever Do This
65_lincoln's Avatar
It looks great Mark. I have a 350mm Momo in my '87 and am so glad to have it (I'm 6'2"). I first drove one in Drago's car and was sold on the improvement both visually and for entry/exit. It definitely blocks my line of sight for the speedo between 60 and 100, (as Mikez mentions) but I know where each 10mph point is by RPM in 4th or 5th gear.
I am curious if the 1" spacer improves the visibility of the gauges? I'd be interested to hear what is obscured for you, as we're about the same height.
Good work!
John
1987 Carrera Targa, Lagoon Green
2012 Audi S4, Monsoon Grey
1965 Lincoln Continental convertible, Maroon--gone but not forgotten
Old 01-12-2007, 10:12 AM
JBO JBO is offline
Big improvement. IMO the Carrerra wheel is one of the ugliest wheels put in a 911.
Old 01-12-2007, 10:27 AM
My visibility of the spedo is about the same with the spacer. Depending on head position I'm blocked at 60 to 70 up to 100. Here's a few pics in better light. BTW, with the 1" spacer, the wheel is 2-1/2" from the dash and 3" from the turn signal switch...very comfortable distances!
Mark
1987 911 Coupe
Old 01-13-2007, 06:18 AM
Sultan of Sawzall
rouxroux's Avatar
Looks great Mark! We run a Nardi 360 and a smaller Momo Corse in our 86's, and we simply rotated the speedos a bit counter-clockwise to "free up" the needed sight area.
Gruppe B #319
'66 Monza coupe 110/PG(white)
'95 993 cabriolet (wife's)
Old 01-13-2007, 06:33 AM
I finally bought that spacer last year. Should have done it long ago.
great improvment, except signal and wiper levers are farther away and I miss them all the time with my fingers.
Turning the speedometer so you can see 100+ mph works.
at least you'll know if you're going to jail or not
Old 01-13-2007, 06:49 AM
Non Compos Mentis
Both my 911 and the 944 race car have 350mm Momos. Huge difference. Especially getting rid of the "bus" steering wheel that the factory put in the 911 in 1973.
I do some autocross instructing, and whenever I get in a car with a stock wheel, I wonder how anybody can drive with that big pig of a wheel.
Old 01-13-2007, 08:30 AM
FinallyGotOne's Avatar
yeah looks the same as my 79 SC. Looks great!
1979 911 SC
1974 OEM 911 Exhaust and Muffler - Modified to a 2-out
Fiberglas Goodies, 17" C4 Cup Wheels
Old 01-13-2007, 08:33 AM
Send a message via Yahoo to algs911
I'm thinking of doing the same thing, however I have a question.
Does your hand hit your leg when cornering with the new wheel? This is my only major issue with the stock wheel.
Looks really nice though. Thanks for the pics. The Momo looks right at home!
Al
Old 01-13-2007, 09:11 AM
Al, I sometime had the same prob with hand hitting the leg......not any more! In addition to the smaller sized wheel, I think the spacer helps with this issue. It's so much more comfortable all the way around. Wish I'd done this earlier.
Mark
1987 911 Coupe
Old 01-13-2007, 09:41 AM
PeterCarrera84's Avatar
Send a message via Yahoo to PeterCarrera84
Looks very nice , did you need special tools to pull the wheel off? and how difficult is it to do ? time wise etc ? I am new in this forum, amd I am enjoying all the Information and education Iam getting here !!! thanks and regards ////////////////////peter
84 911 Carrera SOLD not forgotten
01 911 C4 factory Aerokit
76 914 rust bucket SOLD !!
03 Boxster S sold
98 944 S2 G Red,sold 04 FRC red Vette
Old 01-13-2007, 09:44 AM
Mark, looks awesome. I have long legs and when they're comfy my arms are further away from the wheel than I'd like. I'm going to go with a Monte Carlo wheel and wasn't sure about the spacer. Will definitly install one as well after seeing & hearing your praise of it.
Get your care package yet?
O2 In Sully We Believe
Old 01-13-2007, 09:53 AM
Peter, it's a pretty easy job provided your steering wheel nut isn't frozen........mine had been off recently when PO replaced the windshield so the nut came loose easily. If yours is on tight, trick is to use a anti-theft bar for leverage as it is not advise to torque against the integrated wheel lock.
Horn pad pulls straight off on an 87. You'll need a short (std) 27mm socket (you can buy sockets individually at Sears) and a minimum 3" extension. A deep socket won't work.....you'll know why when you pull the horn pad (extra trip to Sears to exchange sockets for me!)
Next step is to pull the turn signal cancel ring off the factory wheel and install on the new hub.
All that's left is to splice the horn wire that comes with the Momo to the factory wire (b/c the female tab fitting is too small to fit over the momo horn tab) and reinstall the wheel. If all goes well, you're looking at about 1 hour.
Mark, if you've got long legs like me, you will love the spacer....I wasn't sure if I'd need it b/c the momo hub actually pushes the wheel out from the dash a little further than the factory wheel. I actually think a larger spacer might even be a little more comfortable. If you'e got really long legs take a look as some of the sport momo models with "deep dish design" that push the wheel out further. (No care pkg yet....yours is still in the mail too -thanks!)
Oh yea......I forgot to mention the best part..... I picked this "slightly used" wheel up on ebay for $150 shipped.....exactly the wheel I was going to buy new. Sometimes you just get lucky!
Mark
1987 911 Coupe
Old 01-13-2007, 12:24 PM
Thank you Mark, now if I could be as lucky as you, did that include the hub ? and the spacer? thanks again for the directions on how to. and the great pics. I am on the look out !! . ///////// ///////peter
03 Boxster S sold
Old 01-15-2007, 06:02 PM
Unfortunately, no. The spacer and hub were purchased separately.
Mark
1987 911 Coupe
Old 01-15-2007, 06:11 PM
skipdup's Avatar
Anyone know if Porsche horn buttons available for these Momo wheels?
Thanks,
Skip
1972 911T
1972 911E "RSR"
Old 01-15-2007, 06:53 PM
