khamul02's Avatar
Angry Awesome, I'm in Hell! Advise Needed Urgently
Well I started on a few tasks today (replacing trans and engine mounts, installing cat bypass). All was going well until I decided to try and fiure out why my muffler was always a bit low on one side. I thought (HA HA) that it would be as simple as tightening the straps. Not so lucky
Anyway as you can see by the pic the muffler bracket was welded on. GOOD TIMEs!
Question 1: How can I rig somthing up so the other side of the muffler will have some support?
Question 2: Aren't there suppose to be some bolts somewhere around this bracket (the ones normally used to attach it to the case), if so how the hell am I going to get the enigine apart when the time comes? Are these bolt holes covered by the welded bracket?
Question 3: Will I be able to buy this part of the motor (not the muffler bracket) during a rebuild so I won't have a bracket welded to my engine?
Do any of you think someone bought the wrong bracket and rigged it by welding it . . .
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 01-13-2007, 01:22 PM
PRO Motorsports
Tyson Schmidt's Avatar
The upper studs for the cradle are still accessible.
You can see the open hole in the upper left corner where your stud should be, and the other one is very short and only visible from the top , just to the right of the carnk pulley.
So you won't have any problems removing the cradle from the engine when the time comes. In fact, theymade that easier for you by forgetting/neglecting to install one of them altogether.
As far as the muffler bracket goes, I don't know what to tell you. You can either grind off the old bracket and start fresh, or weld on the missing half. Or just buy a new cradle, and swap them out. It can be done in the car if you support the engine with a jack, and remove the rear engine tin.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 01-13-2007, 03:14 PM
khamul02's Avatar
The engine was rebuilt several years back. Given the above I'm a bit concerned about what other shortcuts or just plain half ass techniques were used. I found the broken piece still in the muffler strap. It was well rusted. So I think it's been broken for several years.
Tom Hutchinson
Old 01-13-2007, 03:32 PM
No help but the PO messed mine up too. Check out the hole he hacked in the mount to turn the crank. What a dummy.
John Adams
1980 ROW 911SC
Old 01-13-2007, 07:12 PM
khamul02's Avatar
I think mine was done by the Previous Previous Owner. The PO would never have let this kind of hack job fly! I guess I'll start trying to round up a new muffler bracket and that whole end piece so I can replace them both next time the engine is out.
Tom Hutchinson
Old 01-13-2007, 07:25 PM
They are on ebay all the time.
Mike B.
'72 911E Coupe
Early "S" #1065
Old 01-13-2007, 07:32 PM
khamul02's Avatar
What exactly is that part called? Not the muffler bracket but the part it attaches to.
Tom Hutchinson
Old 01-13-2007, 07:39 PM
khamul02's Avatar
this thing:
Tom Hutchinson
Old 01-13-2007, 07:50 PM
Early_S_Man's Avatar
Porsche Crest
Tom,
Motor Mount Bracket, 911 Coupe & Targa (1974-83)
Brand: Genuine Porsche 911-115-014-03-OEM $210.25
Some documents also call it 'Rear Engine Console' ...
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 01-13-2007, 07:53 PM
khamul02's Avatar
Thanks a ton Warren
Tom Hutchinson
Old 01-13-2007, 08:03 PM
eskimo's Avatar
they're pricey.. Don't be surprised when your jaw hits the floor.
(I know I was)
z's house of boxer, no longer a house of boxer!
03 buell XB9r, 03 Aprilia Scarabeo 50, 06 Jeep Commander 5.7, 88 911 Targa, S2 9.1 sailboat, Santa Cruz 27 sailboat, 18 BMW g310GS, 18 Beetle Turbo
Old 01-13-2007, 10:49 PM
JTL JTL is offline
JTL's Avatar
Arrow
Yeah, and I was surprised how much this part weighs too...
Old 01-13-2007, 10:56 PM
Irrationally exuberant
ChrisBennet's Avatar
It's not the end of the world if you only have one strap supporting the muffler. I bought an '89 3.2 motor once that was missing the muffler bracket. There weren't any "tan lines" on the muffler so it had been that way for a while.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 01-14-2007, 08:02 AM
Get a used one and paint it, save some money.
John Adams
1980 ROW 911SC
Old 01-14-2007, 10:10 AM
Somatic Negative Optimist
Gunter's Avatar
Tom:
Post a "Wanted" for both parts here.
Should be cheap and easy to find.
Hope that the bolts for the engine/transmission were not over-torqued and come out easy. Use antiseize grease when installing.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 01-14-2007, 10:14 AM
randywebb's Avatar
or stamp the two sides out of Ti and then weld together
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 01-14-2007, 10:50 AM
khamul02's Avatar
Since I'm in no rush for the parts I think I'll try to pick them up used via the classifieds. For now I used two open bolt holes and attached some metal strapping to them. Then I ran the muffler strap through that strap. It's on pretty darn good. Now for the test drive: New wevo engine mounts, new sport trans mounts (torque appropriately), and a new cat bypass pipe (more for valve adjustment headache reduction than HP).
Tom Hutchinson
Old 01-14-2007, 01:51 PM
Porsche-poor's Avatar
I have an extra motor mount but it does not look like it has the muffler tabs on it. Is that a seperate part?
'79SC Targa
'2021 CRV
Old 01-14-2007, 05:31 PM
Porsche Crest
This muffler bracket bolts onto the engine mount:
Warren Hall, Jr.
Old 01-14-2007, 08:06 PM
khamul02's Avatar
Here's a shot of the two pieces as they should be:
Don't mind the yellow circles
Tom Hutchinson
Old 01-14-2007, 09:38 PM
