Replace turn signal/high beam switch on a 73 911T
Hi,
Anyone have the patience to walk me thru the process of replacing the turn signal/high beam combo switch for my 73T. For instance, does the steering wheel also have to come off, or can I just snap apart the steering wheel clamshell to get to the screws and wires? Looks pretty straight forward just by looking at the switch and the 8 wires/connectors. But thru years of DIY, I have learned that many things can be deceiving. Any suggestions or links would be greatly appreciated. |
If you are replacing because of the high/low beam not working anymore, suggest you do a search as there are several good threads with pics on repairing your existing stalk rather than replacing it.
Check here for the "fix" vs replacement. Very easy $$$ saver.
http://forums.pelicanparts.com/showthread.php?s=&threadid=248149&highlight=turn+s ignal+switch+quick |
No matter what you do, you will need to pull the steering wheel to remove the clamshell. There are several bolts holding downthe clamshell behind the wheel and horn contactor ring.
| All times are GMT -8. The time now is 01:02 AM. |
