NE Ohio 911's Avatar
Question Lowering with Welmeister Adjustable Spring Plate
Which direction do you turn the eccentric bolt to lower the car?
Doug
1984 Carrera Coupe
Old 01-27-2007, 07:58 PM
Facing the adjusting bolt; lefty loosey to lower. Let's hope you don't run out of threads before you're done.
Sherwood
Old 01-27-2007, 08:53 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
There is no ride height eccentric on the adjustable plates. It's a large set screw. The eccentric on the end closest to the wheel is for camber.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 01-27-2007, 09:09 PM
Chuck Moreland's Avatar
Based on your description, and the fact that your car is an '84, I'm guessin' you don't have weltmeister plates.
Your car came with factory adjustable spring plates, and they do use an eccentric bolt.
You'll need the special purpose-made wrench to turn the eccentric. Push the wrench down to raise the height.
Chuck Moreland - elephantracing.com - vonnen.com
Old 01-27-2007, 09:21 PM
Weltmeister without a doubt. 911Pcars thanks for the info.
I only need to drop 1/4 inch front and back. One complete turn on the front will get me to the right height from what I have learned on the board, any ideas on the back?
Doug
1984 Carrera Coupe
Old 01-27-2007, 09:34 PM
