Can not go to 4th or 5th gear
Hello,
please help, I have took the car out of the body shop were it has been for about 2 years.
The car can not go into 4th or 5th gear, what may be the problem?
Thanks,
Josep
1967 911 Soft Window targa
1969 911S 2.0 targa
1977 911S Sunroof coupe
1979 911 Turbo 3.3
Old 01-18-2007, 09:58 PM
forgot to tell you that is a 1969 2.0 911S. The gearbox is the early style with the 1st. just left under the rear gear.
Josep
1969 911S 2.0 targa
1979 911 Turbo 3.3
Old 01-18-2007, 10:03 PM
Just a guess - sounds like the shift rod can't engage the 4th-5th gear shift fork. Do the 901s have a bottom access cover to inspect this area like the 915s? If they are similar, you should be able to pop the access cover off and see the shifting mechanism.
Chris M
1985 911 Carrera w/ 3.6
Old 01-18-2007, 10:23 PM
Hello,
I have to check if it has this cover, if so, should I drain the fluid before or can take it off directly?
Josep
1969 911S 2.0 targa
1979 911 Turbo 3.3
Old 01-18-2007, 11:24 PM
i don't know much about the 901 style trans but in any other situation i would say that the shifter linkeage sounds to be out of adjustment and could be re-aligned to engage all of the gears properly. this is accessed via the pannel behind the front seats on the top of the tunnel. there is a tech article about it for the 915 on here and i'm sure the procedure has been covered if you look for 901 shift linkage adjustment.
hope this helps.
-felix
a little of this + a little of that
Old 01-19-2007, 03:44 AM
Super Moderator
cstreit's Avatar
Before you go opening the transmission (and all your fluid will come out if you open the shift-fork access plate on the trans) check your shift-coupler.
This coupler is located under the carpet at the rear of the tunnel. It's unlikely that something happened inside the trans while he car was sitting. However if the engine was out or this coupler moved, it could very well be mis-aligned. Do a search on shift coupler alignment on Pelican and you'll see how to do it.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-19-2007, 05:29 AM
