Czar of C.R.A.P.
injector reseal what to use
Yes I know search. I have done that.
When replacing injector seals the kit comes with 3 o-rings 1 fiber ring and 1 plastic cap. What all do you replace. I thought my o-rings would be hard but they aren't so I don't know why they were leaking after being down for a rebuild. But anyhow. Do I just put on the o-rings and leave the rest. Do the little plastic caps just pop off and get replaced along with the fiber. I have seen posts where it says just use the o-ring I am confused. __________________
66 912 Coupe 84 Carrera Cab Hardtop HC3.4 Hyper Carrera 2005 Dodge Magnum 5.7 HEMI Cabriolet Racing And Performance C.R.A.P. Gruppe #1 Put on some C.R.A.P. and drive.... |
The fuel injectors are supouse to use the o-rings. If you dissasembly the fuel rail and the fuel injectors, maybe the o-rings are old. You need to buy a new ones and install it lubricating the o-ring with a little engine oil os petrolleum jelly. That would eliminate your problem.
1972 911T 1991 Mazda RX-7 Turbo II Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life! |
