zbph10's Avatar
Carrera tail rubber base needed
I bought a Carrera tail for my 87 and it didn't come with the rubber seal that goes between the tail and the deck lid.
Are these available or do I need to just fab one up?
I put a want ad in the classified but I figured this gets more traffic.
Brian
1987 911 Coupe-Current ride
2007 997TT-Sold
2006 997 C2S-Sold
1991 964 Turbo-Sold
1987 911 Targa-You never forget your first
Old 01-18-2007, 07:48 PM
Super Moderator
cstreit's Avatar
I'd call PelicanParts and ask them... I couldn't see it online, but I didn't look too hard...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-18-2007, 08:05 PM
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
You can get them from Pelican or the Porsche dealership (I got mine fomr the dealership only because I was buying some other things too).
I changed mine out (tea top tail) about six months ago. The proper seal will come with double-sided tap on the top and the bottom of the seal. Make sure you fit it to the tail properly (you may need to cut the ends of the seal a little bit because they may overlap) and then remove the tape on the side that will secure to the tail and stick it on. Before you attack the tail to the deck lid, make sure the paint on the engine lid is completely free of debris (if present it will damage the lid's paint and the seal). After the cleaning prep is complete have a friend help you verify the tails fit to the lid. Check to ensure each bolt hole matches up with the tail's prefectly. When that is worked out, remove the bottom portion of the double-sided on the seal and fit the tail to the lid. Screw in each bolt hand tight and then tighten the bolts up completely.
It should look great with the new seal installed!
Here are some pics of when I did mine:
Old gasket had been reused sever times by previous owners or mechanics and caused damage to the engine lid and the wing. The seal also was dry-rotting.
Pretty simple. Line it up as you go and remember to clean the mating surface of the with mineral spirits or paint thiner to remove anything that might prevent the tape on the seal from adhering properly. The corners are the trickest part, but go slow with it and it will be easy.
Remember to line up the seal's bolt holes with the bolt holes in the tail.
Six months later and the seal still looks great!
Hope this helps,
Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 01-18-2007, 08:34 PM
zbph10's Avatar
Thanks for the pictures, I'll call Pelican right now
2007 997TT-Sold
2006 997 C2S-Sold
1991 964 Turbo-Sold
Old 01-19-2007, 01:18 PM
zbph10's Avatar
Just need to learn how to search, Pelican sells them for $16.25
2007 997TT-Sold
2006 997 C2S-Sold
1991 964 Turbo-Sold
Old 01-19-2007, 01:25 PM
