Spark Plug Gapping Tool?
What are you guys using to gap your spark plugs precisely?
I have a pretty good Kinchrome Feeler gauge for checking plug gaps up to 0.040", but I'd like to get myself an accurate gapping tool. I've seen the coin type of gapping tools, but have read they aren't very accurate. I've read of people using pointy nose pliers, but this makes me nervous :confused: Anything out there that's reliable and consistently accurate? |
Hi Merv,
I was taught way back in high school auto class (many years ago)that one should always use a round wire type of gapper. The idea is that the round wire will be of consistent size and a wedge type gapper will always be off to one side.....follow? I still use my old wire type gage. |
Bosch makes one
http://forums.pelicanparts.com/uploa...1169499333.jpg http://forums.pelicanparts.com/uploa...1169499345.jpg -Chris |
Cool! How does one go opening the gap with that tool?
A mechanic friend of mine has the coolest gapper I have seen. I looks like one of those old label makers with the squeese handles. There is a dial on the top that he adjusts to the desired gap. The plug goes into a slot and he squeeses the handles together. It takes about two minutes to gap 6 plugs and they are indentical every time. I think he said it was either Mac or $nap-On. I havent seen one for sale on the reatil circuit.
In two minutes I can gap 20 plugs by hand and drink a beer at the same time. lol
Even a sloppy gab job is off by +/- .002. I wouldn't sweat the small stuff. |
Which type of gaping tool can make the ground electrode parallel to the center electrode? Or would that be true perpendicular?
That's what I want. http://www.wkjeeps.com/engine/spark_plug_gen.jpg |
Some higher compression motors don't like the longer ground strap at all. It can act as a heat sink and cause pre-ignition problems.
http://forums.pelicanparts.com/uploa...1169499333.jpg - you use the long lever with the hook to bend the electrode -nice pic, Chris |
I bought one off the Snap-On truck 30 years ago. It's a pliers type. Rotate the head for desired gap, insert plug on stirrup and squeeze. Done. I've seen the same one at Sears and other tool houses.
http://www.amazon.com/Jacobs-380700-Gapping-Pliers/dp/B000BW8T14 Quote:
Anyone have another suggestion? |
Those are around $138 down here in Aus :mad:
Damn it, our local Jacobs distributor/supplier no longer brings these in :mad: I'll have to import one I suppose :confused:
Go to Aircraft Spruce or Wicks and see what they're selling for the gapping of aircraft plugs. The one I useta use was very precise and not that expensive.
Hey Merv, That's almost the same one I have. Mine doesn't have the upgraded cushy handles.
#138??? Look at the thing - it's stamped steel. At that price they should be hand-carved by Andalusian Vegan Virgins.
For e.g: if I want to gap a plug to 0.032", I need to set the dial to ~0.028" :confused: Just make sure you're aware of this, and always double check your gap with a proper spark plug feeler/gapping gauge. 0.004" is a large discrepency, especially when you're talking spark plug gaps! The only thing I really like about this tool is the side notch which allows you to bend up the side electrodewithout touching/damaging the centre elecrode. |
| All times are GMT -8. The time now is 09:25 AM. |
