WydRyd's Avatar
Question Spark Plug Gapping Tool?
What are you guys using to gap your spark plugs precisely?
I have a pretty good Kinchrome Feeler gauge for checking plug gaps up to 0.040", but I'd like to get myself an accurate gapping tool.
I've seen the coin type of gapping tools, but have read they aren't very accurate.
I've read of people using pointy nose pliers, but this makes me nervous
Anything out there that's reliable and consistently accurate?
ARE THESE ANY GOOD???
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 01-22-2007, 03:08 AM
Slippery Slope Victim
NY65912's Avatar
Hi Merv,
I was taught way back in high school auto class (many years ago)that one should always use a round wire type of gapper. The idea is that the round wire will be of consistent size and a wedge type gapper will always be off to one side.....follow?
I still use my old wire type gage.
MikeČ
1985 M491
Old 01-22-2007, 04:42 AM
randywebb's Avatar
Bosch makes one
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 01-22-2007, 12:17 PM
Irrationally exuberant
ChrisBennet's Avatar
Originally posted by randywebb
Bosch makes one
I got my Bosch one years ago from Imparts (remember them?).
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 01-22-2007, 12:56 PM
WydRyd's Avatar
Cool! How does one go opening the gap with that tool?
Merv
'89 911 Turbo Cab
Old 01-22-2007, 01:07 PM
A mechanic friend of mine has the coolest gapper I have seen. I looks like one of those old label makers with the squeese handles. There is a dial on the top that he adjusts to the desired gap. The plug goes into a slot and he squeeses the handles together. It takes about two minutes to gap 6 plugs and they are indentical every time. I think he said it was either Mac or $nap-On. I havent seen one for sale on the reatil circuit.
Mike.
1972 911T, non-sunroof coupe.
Old 01-22-2007, 01:14 PM
Registered abUser
TerryH's Avatar
In two minutes I can gap 20 plugs by hand and drink a beer at the same time. lol
Even a sloppy gab job is off by +/- .002. I wouldn't sweat the small stuff.
'81 911SC Coupe SOLD
Old 01-22-2007, 02:43 PM
Which type of gaping tool can make the ground electrode parallel to the center electrode? Or would that be true perpendicular?
That's what I want.
Old 01-22-2007, 02:51 PM
Registered abUser
TerryH's Avatar
Some higher compression motors don't like the longer ground strap at all. It can act as a heat sink and cause pre-ignition problems.
That's what I want.
Old 01-22-2007, 03:08 PM
randywebb's Avatar
- you use the long lever with the hook to bend the electrode
-nice pic, Chris
Old 01-22-2007, 03:56 PM
shbop's Avatar
I bought one off the Snap-On truck 30 years ago. It's a pliers type. Rotate the head for desired gap, insert plug on stirrup and squeeze. Done. I've seen the same one at Sears and other tool houses.
Jon
Old 01-22-2007, 04:31 PM
WydRyd's Avatar
What about something like this???
Merv
'89 911 Turbo Cab
Old 01-22-2007, 06:52 PM
http://store.summitracing.com/egnsearch.asp?N=700+400360+115+303686&autoview=sku
Jacobs Gapping Pliers
Gap correctly, gap quickly.
These Jacobs Gapping Pliers can gap your spark plugs accurately and consistently. No more banging the plug on the counter to get it "close enough." These pliers work on nearly every single electrode automotive plug, and are durable enough to be used in backyards or in the pits.
About $40.00
http://www.amazon.com/Jacobs-380700-Gapping-Pliers/dp/B000BW8T14
* specially made set of pliers that Acurately and consistently gaps sparkplugs with the outer electrode perfectly perpendicular to the center electrode every time
That's what I had in mind - thanks.
Anyone have another suggestion?
Old 01-23-2007, 08:15 AM
Thats exactly what I was talking about. Where did you find that and how much are they? The mechanic friend I was referring to builds race engines for a living and swears by it. When I asked him how much it was he replied "you don't want to know and I would be embarrassed to tell you".
Mike.
Old 01-23-2007, 11:38 AM
Read my post above.
Old 01-23-2007, 11:39 AM
Read my post above.
Got it, I didn't see that you had quoted WydRyd in your post. But I went back and clicked on your links after the fact. THANKS.
Mike.
Old 01-23-2007, 11:45 AM
WydRyd's Avatar
Those are around $138 down here in Aus
Merv
'89 911 Turbo Cab
Old 01-23-2007, 01:44 PM
WydRyd's Avatar
Damn it, our local Jacobs distributor/supplier no longer brings these in I'll have to import one I suppose
Merv
'89 911 Turbo Cab
Old 01-23-2007, 05:25 PM
Go to Aircraft Spruce or Wicks and see what they're selling for the gapping of aircraft plugs. The one I useta use was very precise and not that expensive.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 01-23-2007, 05:58 PM
shbop's Avatar
Hey Merv, That's almost the same one I have. Mine doesn't have the upgraded cushy handles.
Jon
Old 01-25-2007, 05:32 AM
