450knotOffice's Avatar
Question Windshield wipers not working all of a sudden - fuse is fine
Yesterday, to my surprise and consternation, I found that my wipers were inop. They've always worked fine up until now. I just checked the fuse and it's fine (and I get power to both sides of the fuse). I'm hoping that the motor hasn't decided to fail on me, so have any of you guys seen this scenario and if so, what has been the problem?
Old 01-22-2007, 12:42 PM
bump
Old 01-22-2007, 02:38 PM
Scott,
Had something similar happen to me. Wipers worked when I shut the car off, and the next morning they didn't. Turned out it was the switch. I don't know anything about the electricals (a friend diagnosed this problem for me), so I can't comment on your getting power to both sides of the fuse. Good luck!
Old 01-22-2007, 07:48 PM
Turned out it was the switch, eh? Hmm. I can deal with that a lot more easily than trying to get back to the wiper motor, which is back behind the fresh air blower in the trunk, which is a PIA to R&R.
Old 01-22-2007, 08:35 PM
Sports Purpose 911 Driver
mjshira's Avatar
check your ground wire at the wiper motor, you can access it from behind the clock, if it is connected then move to the switch. good luck
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 01-23-2007, 05:30 AM
I'll try that, James. Thanks.
Old 01-23-2007, 09:39 AM
BlueSideUp's Avatar
Send a message via AIM to BlueSideUp
Wiper problems must be going around. Mine just stopped too. I should be able to diagnose it later this week.
I just have another little project to finish first.
-Jess
Old 01-23-2007, 12:10 PM
check the plug that goes through the cowl. they can come loose. 3 in a row. ign/tsig/wipers.
206 637 4071
Old 01-23-2007, 12:15 PM
Diss Member
Quicksilver's Avatar
John Walker is talking about the connections that are under the dash right over your left knee.
I have a good switch that I snapped the stalk off of that can be used to test it. If you want to try it the only question is how to get it to you. I work in Irvine (near Jamboree and 405) and I know you live farther south. Tell me if you want to see if we can cross paths and test it.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 01-24-2007, 07:32 AM
With mine it was tje switch on the steer, they also replaced the interval switch. Was typical Porsche expensive.
carrera coupe 85
Old 01-24-2007, 09:39 AM
Wayne, I emailed you..twice. Thanks for the offer.
Old 01-24-2007, 10:06 AM
