1973 911T Targa Introduction
Fellow Pelicans,
I have been watching and learning from this board for a while now and thought I should post some pics and introduce my 911. I bought this--my first Porsche-- in AUG 06. Stats: -1973 911T Targa -2.4 engine -5 speed 915 transmission -About 200K miles Modifications (all done from 1983-1984): -PMO Webers Installed -Steel RS Flares -Ducktail -Old interior replaced with mid-70s variety -Painted Dark Blue--origionally silver History: I have records back to 1980 -All reciepts from california until 1997 -From 1997 until now it was in the Washington DC area. Condition: -No rust problems -- except some bubbles on the hood where a bra used to be and some bubbles around the windshield that are probably worse than they look--other than that pretty straight. -Engine runs strong once warmed up Projects so far: -Changed fuel pump -I stripped all the black paint from the trim and rollbar. -Minor maintenance--changed oil/replaced valve cover gaskets/etc. Projects working now: -Replace black plastic mirrors w/chrome -Replace black door handles w/chrome Future Projects: -Install carerra chain tensioners -Reupholster front seats--(they aren't origional but they are comfortable) -Replace windshield gasket--Front gasket leaks on sides The car is a lot of fun to drive and handles really well. It took me about a year to find this one -- it's hard to find ones in the mid-atlantic without rust issues -- but I'm glad I hung in there. Adrian
Nice loking car! Welcome to the board.
Mark
Mark Isaak 1974 Carrera Targa - Light Yellow, Being driven 1974 Carrera Targa - Orange, Being restored 1974 Carrera Targa - Lime Green, Being pampered 2017 Macan |
Side view:
Home of the Whopper
Sweet ride. I'd also strip the paint off the front bumperettes.
Where in the mid-atlantic are you? I believe there are many Pelicans in the VA/DC/MD area.
1968 912 coupe 1971 911E Targa rustbucket 1972 914 1.7 1987 924S |
cycling has-been
the leaks might not be from the windshield gasket. you mentioned rust bubbles on the cowl. that would be my first guess, unless the windshield was replaced incorrectly at some time.
Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
Bill,
I know the windshield gasket leaks as I watched it come through when I was washing the vehicle. I am not sure about the cowl is there a tell tale symptom of a cowl leak? BK911, I started to strip the front and back bumperettes but I have one front and rear bumperette that were origionally black from the factory --no hiding chrome. The other two bumperettes are chrome--so I will just keep them black for now. I'm in the Falls Church area. Thanks, Adrian |
cycling has-been
if water is getting in through the cowl, (most likely the seam between the fender and the cowl), there will be tell-tale rust tracks on the kick panel inside, under the carpet.
btw, the 73 had unique rubber bumperettes f & r, no metal. Bill K
Bill,
Thanks for the tip, I don't see any evidence of a cowl leak but I will monitor. I know the 73 should technically have the rubber bumperettes but I prefer the look of the old metal ones. Thanks, Adrian |
durn for'ner
What a sweet ride. I really, really need a longhood. Funny how, IMO, PAG never managed to make them as beautiful again. The 993 may be close, but nothing beats the pre - 74 cars.
Markus Resident Fluffer Carrera '85 |
Welcome to Pelican...we longhood types must stick together, because we're slowly becoming extinct...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Welcome & congrats on acquiring a beautiful car. I had a leaking problem from the windshield of my '72. When I would wash the car, a little water would leak in on the driver side floorboard. When I finally removed the windshield, I found tons of rust damage in the bottom corners, and on the driver side, it had rusted part of the metal on the top of the dash under the dash pad. So, I'd check that out if I were you and hope you take care of it in time. Fun cars to drive! Good luck.
Marv Evans '69 911E |
Marv,
Thanks for the advice--I'll move that job up on the priority list to check for any potential issues. Adrian |
Beautiful longhood! Very tasteful projects....
1972 911T targa |
19 years and 17k posts...
Nice Targa! Welcome aboard!!
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Coldstart, you need to post more pic's of that Targa! That looks sweet!
1971 Albert Blue T Targa RG 439 ES 1056 |
